Anyone have I30 dash disassembly instructions? (radio install)
Old Mar 17, 2004 | 10:08 AM
phenryiv1's Avatar
Mod her. Ate her.
Does anyone have dash disassembly instructions for the 96-99 I30? I need to get to the back of the BOSE to install a Peripherial adapter, but I only have the Maxima instructions. With the different vent assembly, it HAS to be a different process, and I do not want to break something.
Anyone have any info or instructions to help me out?
Old Mar 18, 2004 | 05:32 AM
Asian_N02's Avatar
-There are clips holding down the wood around the shifter assembly. Just stick a screw driver under there and pop it up. Just be very gentle as you don't want to break it. Make sure you work your way around it.
-There are clips holding the vent in as well. If I remember correctly, you can pry from the bottom of the vent to get to those clips. I think there are 3 clips.
-I think you have to unscrew your ashtray next. I can't remember exactly what it looks like, but it's pretty straight forward.
-Once you get all those pieces above undone, there are 4 screws holding in the climate control, Bose HU, and tray. Unscrew those and the whole assembly will come out.
-I think there are 4 or 6 screws holding the Bose HU in place. Unscrew those and the Bose HU is out.
I hope these directions shed more light on your situation. I apologize if I wasn't too clear, but it should give you a start. Good luck!
Old Mar 18, 2004 | 08:00 AM
phenryiv1's Avatar
Mod her. Ate her.
It was these two steps that I needed to verify. Everythign else is just like the Maxima.
Thanks!
Old Mar 29, 2004 | 08:16 PM
baracus's Avatar
same process as the max.
Old Mar 31, 2004 | 07:11 AM
Pizatt's Avatar
Very easy, same as a max...
doctorpullit
Oct 11, 2015 10:28 AM
Behuvius
Sep 14, 2015 01:49 PM
Johnny9595
Sep 3, 2015 05:18 AM
Jeffesernia11
Aug 23, 2015 06:09 PM
kirkhilles
Aug 8, 2015 10:53 AM
