How low can i go ???
Old Apr 1, 2004 | 05:00 PM
I30_DRIVER's Avatar
Hi to all of my INFINITERS. I had a question .
I wanna lower my car ,what is the best looking drop for this car,safest.
Do you guys recomend going with sprint springs and struts?
What would be the best setup?
Coming soon 19' lorinser rims
Thanks for the support...
Old Apr 2, 2004 | 08:47 AM
phenryiv1's Avatar
Mod her. Ate her.
On 19"s with sprints, it will be a parking lot queen that will be too rarsh to drive on most PA roads. Try Eibachs, H&Rs, Intrax, or maybe the new Teins.
Adjustable struts are a good idea (Tokico Illuminas are good ones, and a lot of guys run KYB AGX).
Tokico has an all-in-one setup w/ springs and struts, as well.
Sprints are very low and very harsh, as springs sgo for the max/i30.
Some people like them, but on 19"s you are asking for trouble.
Old Apr 2, 2004 | 09:26 AM
NewLoveI30's Avatar
If you can afford 19" Lorinsers, maybe you should consider a nice coilover setup.
Ive heard they can be set to be pretty comfortable, but when you want to go low, you can go allll the way.
Just a thought.
Old Apr 2, 2004 | 12:34 PM
PhillyDonut's Avatar
Sprints with AGXs on Philly roads are not too bad. It's bearable but you do have to watch out for pot holes. Sprints are stiff and with 19" you are going to get a hell of a bumpy ride... I ride on stock 15" with my setup and "feel" every bump. If you are set on going low but can't afford a full coilover setup, Sprints are the way to go, but I would advise you to get Illuminas, which there's a good group deal on them now (or Konis , and not the AGXs. Also, your lower front bumper and cat will scrape on some philly roads. depends on where you are. I don't even care about scraping anymore... hehe
pd
Old Apr 2, 2004 | 07:58 PM
I30_DRIVER's Avatar
thanks alot for the advise i think i will consider sprint spring with kyb agx's
any thanks alot
philly donut were you by tweeter about a week ago?? on the boulevard?
Old Apr 3, 2004 | 10:23 AM
any thanks alot
Possibly.. I go to Best Buy, Tweeter, and Nes. theater. Are you in the northeast area?
Old Apr 3, 2004 | 12:44 PM
I30_DRIVER's Avatar
INDEED...
listen i have couple of friends with maximas and I30's
we should make a meet sometimes
Old Apr 4, 2004 | 01:01 AM
yeah. that's cool. hit me up with a pm when something happens. maybe something with Jersey too? just an idea.
pd.
oh, another thing. if u r auto, i "highly" advise you to cut the rear Sprint springs. At most I recommend cutting 1 coil only... else the spring won't have any compression when mounted on the shocks and could potentially move out of place when the car is lifted.
Old Apr 4, 2004 | 05:38 AM
I30tMikeD's Avatar
if you care at all about ride quality you wont get sprints with 19's. H&R, progress, or maybe Eibachs. If you want to do it right get JIC or Tein coilovers
Old Apr 4, 2004 | 07:01 PM
I30_DRIVER's Avatar
OK THANKS FOR THE ADVICE I30tMikeD
I WILL TRY TO FIND TEIN'S FOR A GOOD DEAL
P.S. FOUND OUT HOW MUCH LORINSERS COST....
CHANGED MY MIND.ILL GO WITH 18'
CHEAPER BRAND DONT WANNA PAY 1350$ FOR EACH RIM...
Old Apr 5, 2004 | 07:17 AM
phenryiv1's Avatar
Mod her. Ate her.
pd.
Exactly what benefit are you saying that he will have if he cuts a set of Sprints?
phenryiv1's Avatar
Mod her. Ate her.
Please stop typing in all caps.
Teins are about $135 for S-Techs and $165 for H-Techs.
Old Apr 5, 2004 | 04:05 PM
Don't cut the set Sprints, just the rear two. I initially installed them out of the box and 1. it leaves the rear noticeably higher than the front and 2. the ride is stiffer (prob because all of the weight is directed towards the front because the rear is higher plus weight of engine). Three months later, I decided to get a coil cut off the rears and it evens the height a bit (the rears are still slightly higher, but not very noticeable, maybe 1/8 inch or so) and ride quality increased. I'm not a suspension expert, but there was definite a noticeable decrease in bumpiness by me and friends who ride in my car. This is not to say you won't be bumpy because you sure will. Too bad Teins weren't available at the time, else I'd consider those.
Again, this is just "my" feedback based on my experience. You're actual experience may vary.
pd
Old Apr 5, 2004 | 04:28 PM
phenryiv1's Avatar
Mod her. Ate her.
pd
While I normally run around saying "never cut springs!' you seem to have a logical reason for what you are advocating. It makes much more sense the way that you explained it. I have never heard of another spring type being higher in the rear, but I also have not bothered to learn much about Sprints.
Carry on, fellas, carry on...
Old Apr 5, 2004 | 09:51 PM
I30_DRIVER's Avatar
No ut springs for me my 318ti bimmer was cut enough never was able to get my car aligned
Old Apr 5, 2004 | 09:54 PM
I30_DRIVER's Avatar
No cut springs for me my 318ti bimmer was cut enough never was able to get my car aligned
Old Apr 9, 2004 | 07:35 PM
BEEI30's Avatar
Here are Tein coilovers with 17" G35 sport wheels
Old Apr 10, 2004 | 06:45 PM
I30_DRIVER's Avatar
looks low enough for me but the thing is mine is the a32... and how much do they go for?
Old Apr 12, 2004 | 07:07 AM
phenryiv1's Avatar
Mod her. Ate her.
I30_DRIVER-
And I will be selling them soon to go to a higher spring. They are Intrax.
Old Apr 12, 2004 | 07:34 PM
I30_DRIVER's Avatar
tell me this what setup is it intrax springs and what kind of struts?
how rough is the ride?
thanks
Old Apr 13, 2004 | 05:18 AM
phenryiv1's Avatar
Mod her. Ate her.
Paired w/ AGX...Ride is more stiff than my old H&Rs, but the handling is improved at the same time.
Old Apr 14, 2004 | 10:36 AM
I30_DRIVER's Avatar
i need an advice should i go with kyb agx shock,
and sprint springs, s tech tein's?,intrax? i like it low
Old Apr 14, 2004 | 10:46 AM
phenryiv1's Avatar
Mod her. Ate her.
Is it auto or manual? You will have 18"s right? How much are you looking to spend on the suspension setup? It is going to be $500 (give or take) to do it right.
Old Apr 14, 2004 | 06:58 PM
I30_DRIVER's Avatar
im gonna go with agx's and h&r for 500$ shipped
Old Apr 15, 2004 | 06:04 AM
phenryiv1's Avatar
Mod her. Ate her.
That will be a sweet setup. One peice of advice- CHANGE YOUR STRUT BEARINGS! If you do not, you will regret it down the road.
Old Apr 22, 2004 | 06:21 PM
I30_DRIVER's Avatar
phenryiv1
tell me this what benefit am i going to get out of replacing strut bearings.? got my short shift kit feels great its pace setter adjustable...
its pretty short throws thogh the hight looks the same.
is there any benefit in cutting it?
thanks ...
Old Apr 23, 2004 | 10:18 PM
TheAdmiral42's Avatar
Where are you getting that setup from? I am interested in getting it myself.
Thanks.
Old Apr 24, 2004 | 01:35 PM
I30_DRIVER's Avatar
Its my friends in philadelphia they own a speed shop called grand prix and they are getting me that sweet deal i think its a dealer cost...
Old Apr 24, 2004 | 02:05 PM
Anyone know anywhere I can get a deal like that?
Or anyone have any reccomendations?
I am putting my i30 on chrome 18"s, if I can get the H&K's and the AGX's I think I'll cream my pants.
I'll guess I'll be searching the forums...
Thanks.
Old Apr 26, 2004 | 08:52 AM
phenryiv1's Avatar
Mod her. Ate her.
phenryiv1
tell me this what benefit am i going to get out of replacing strut bearings?
When you turn the wheels, all components in the strut assembly turn with them. The strut bearing allows the components to turn freely. With work or faulty strut bearings, the springs "wind up" and bind as they are turned. This makes noise and is really annoying. The person who owned the car before me did NOT replace the bearings, and now I am left to replace them, which is a pain in the butt.
If you plan to keep your car, and if it has more than abotu 35K on it, replace the strut bearings.
thanks...
If it is shorter in height, it will be more difficult to move the shifter (simple physics). It will look cooler and will be out of the way, but if you have a drink in the cupholder, it will be more difficult to actually shift because the cup may be in the way.
Old Apr 26, 2004 | 07:42 PM
I30_DRIVER's Avatar
well im fine with it being more difficult to shift .
i kinda like that and DRINKS!!!! in my cup holder nah ahh ....
anyway will deffinetly get bearings are they expansive?
thanks
Old Apr 27, 2004 | 05:06 AM
phenryiv1's Avatar
Mod her. Ate her.
thanks
I cannot remember---maybe $35 for the pair.
Old Apr 27, 2004 | 05:55 PM
I30_DRIVER's Avatar
oh then in that case its a 100% go
once again thatnks for the info and the support
litch
123
Jan 4, 2024 07:01 PM
aw11power
Oct 10, 2021 04:57 AM
sliptap
Sep 30, 2015 05:57 AM
