I35 shifter on I30
Old Jun 7, 2004 | 08:20 AM
speye022's Avatar
I35 shifter on I30
I want the wood grain shifter from the I35, but I have an I30. How can I leave the overdrive on and install the wood shifter?
Old Jun 7, 2004 | 08:37 AM
NewLoveI30's Avatar
I still want to know if I could modify and install the entire I35 gated shifter. I was asking if someone could take a picture of the shift linkage under the console so I could compair and see if it could be done without too much work. I am almost certain it is the same tranny.
As for just replacing the stick. You probably would lose O/D off unless you hooked up a button to the dash or something. Even then I think it would be too much work and not look very good.
Do a search on Maxima automatic shift *****. I know there are some aftermarket ones, but the ones I have seen dont look very good.
Old Jun 7, 2004 | 08:41 AM
NewLoveI30's Avatar
I dont know if this is what you ment, but if you did replace the shifter, the overdrive would always be on. You just wouldent be able to turn it off.
Old Jun 7, 2004 | 11:01 AM
mikeI302k's Avatar
the tranny should be the same but i have seen shift ***** for the auto w/od at autoaccessorystore.com its got a nice look to it its just not wood
Old Jun 7, 2004 | 01:15 PM
NewLoveI30's Avatar
I have seen a few (with the O/D) that looked ok, but when installed they looked really bad because they were WAAAY too tall.
Old Jun 7, 2004 | 05:28 PM
speye022's Avatar
I could live with that. I have been driving with the O/D on without problems or need to switch it off. So basically make sure the O/D is on before I install the wood shifter?
Old Jun 8, 2004 | 05:05 AM
mikeI302k's Avatar
o/d turns back on when you start the car so its automatically going to stay on all the time.
Old Jun 8, 2004 | 07:13 AM
nguyendot's Avatar
Buy an the whole car (and 255hp), not just the shifter! Hehe
Old Jun 8, 2004 | 08:32 AM
speye022's Avatar
Cool...thanks
mclasser
22
Nov 12, 2020 01:58 PM
Fbana41
Aug 29, 2016 12:18 PM
maxinout93
Oct 31, 2015 02:04 AM
atriuum
Sep 28, 2015 01:19 PM
