Bulb size
Old Nov 9, 2004 | 04:01 PM
SuBXeRo's Avatar
Bulb size
what is the bulb size of the bulbs in the temp guage. and also are they very tempermental, cause i took one out to switch it with the other that was blow and then the other one blew out and now all the bulbs are dead. i took the blue plastic off cause i didnt want it anymore, but even the one that i kept the plastic on blew out.
any ideas?
Old Nov 10, 2004 | 05:22 AM
HomerMAC's Avatar
Donating i30 Owner
controll lights red.. only problem is does anyone know how to change the light on the bose radio..? cause i want it ALLL RED.. sorta looks a bit more aggressive in my oppinion....
Old Nov 10, 2004 | 07:59 AM
SuBXeRo's Avatar
thats what im doing in my car red, but u dont know the bulb size?
Old Nov 10, 2004 | 10:37 AM
Max Mutes's Avatar
What exactly do you mean by Temp. Gauge, on the cluster or the Auto Climate Control Temp? Well ,the Gauge cluster bulb is a 194 Wedge LED direct replacement. The Auto Climate Control needs 3 - 3mm LEDs with resistors for each, then you need more LEDs for the control buttons like Defog, Circulate, Off, etc.
Old Nov 10, 2004 | 11:19 AM
SuBXeRo's Avatar
well im talking about the lights that light up the buttons on the temp guage that have mounts like the 194 bulbs do on the guage cluster
Old Nov 10, 2004 | 11:23 AM
Max Mutes's Avatar
lol, I don't think I should be, but I am...*scratches head*
Old Nov 10, 2004 | 01:11 PM
Dr.Monkey1313's Avatar
I'm confused as well.
The temp guage (in your guage cluster) uses a 194 bulb
The temperature controlls (the AC unit) apparently uses 3mm LEd's with resistors for each LED.
Did that help at all? "scratching head as well."
Old Nov 10, 2004 | 02:41 PM
SuBXeRo's Avatar
not the temp guage is the cluster i totally forgot about that sorry i mean the ac controls. if you look at it there are little orangy red things. about 4 of them in the back. if u unscrew them the holder and the bulb inside comes out as one piece.
Old Nov 10, 2004 | 03:41 PM
HomerMAC's Avatar
Donating i30 Owner
hmmm so there all LEDS behind hte temperature controls..? and 194 wedge behind the guage cluster..? and also what do i change to ge tthe display.. the temp/fan/bose head unit/ clock.. all those to show red..? imean what would i change..? anybody did this before..
Old Nov 10, 2004 | 05:12 PM
SuBXeRo's Avatar
this is all pretty new here people are just really starting to do this, doesnt seem like its been done too much b4.
ok heres the break down of what i know
Guage cluster (speed, tach, temp, gas) all use 194 wedge bulbs 5 bulbs total 2 for the speedometer 1 for the rest.
Door lights are also 194 wedge bulbs
Old Nov 11, 2004 | 07:51 AM
Yes, the above info is true. Here is a link that may help people with the other bulbs in the car if interested. http://www.sylvania.com/ConsumerProd...de/default.htm
For my window switches I used LED's from the windshield washer LED's you can buy at Walmart. I just broke them out and used the LED's from them. They went on without any resistors. Just FYI.
Miket2006
Mar 1, 2021 03:55 AM
doctorpullit
Mar 29, 2016 11:08 AM
mpbclutch33
Dec 26, 2015 11:11 AM
knight_yyz
Nov 1, 2015 01:34 PM
