How do you get the Hid's out of a I35???
Old Nov 19, 2004 | 04:43 PM
ManualMaxima's Avatar
5th Gen till she dies!
no i am not stealing them, but the hood will be open all so do not worry about that.
How do you get the Hid's out of a I35? i need all the part so i can just put it in another car. how do you get everything you need out,a nd how long might this take?
Old Nov 19, 2004 | 09:41 PM
gqmac2's Avatar
check the owners manual or take it to the Inifiniti Dealer. Its not an easy taks though. (Its designed so people can't steal the bulbs easy.)
Old Nov 19, 2004 | 11:24 PM
it is in a junk yard so i really can't.....so it is not to easy tot everyhting out cause i do not want to spend a whole day there looking out how to.
i want to take bulbs and ballasts out.
Old Nov 22, 2004 | 01:35 PM
MetaOrbit's Avatar
Got Projectors?
http://forums.maxima.org/showpost.ph...0&postcount=13
Old Nov 22, 2004 | 08:50 PM
bi30's Avatar
how much are they charging?
Old Nov 22, 2004 | 09:26 PM
roofadoofalus's Avatar
it took me a very long time to remove the headlight from my millenia when i had it
Old Nov 22, 2004 | 10:47 PM
mikeI302k's Avatar
when you get the headlights out which takes about 15 min each. you will see that the ballast is screwed on to a special holder. unscrew that then just follow the rest of the process you'll see the rest of the bolts and screws once you get the ballest off. just be carefull with the bulb becasue if one spec of dusk and it blow.
Old Nov 23, 2004 | 07:04 AM
HomerMAC's Avatar
Donating i30 Owner
ahh the bulbs arnt that fragile.. i mean u should take special care in it.. but its not that fragile..
Old Nov 23, 2004 | 12:25 PM
are the starters and ballasts one? or are they seperate peices?
Old Nov 23, 2004 | 01:49 PM
HomerMAC's Avatar
Donating i30 Owner
ahh starters.... .... u mean the ignitor rite..? okay i guess.. ahh on the nissan cars.. they have ballasts then the ignitor seperately.. the ballast has liek orange and yellow... and the ignitor is black.. its like a blak block... .the kit i use .. had the ballast and ignitor in one.. then the bulb and adapter connects tot eh ballas/ignitor..
Old Nov 23, 2004 | 02:23 PM
yea the kti i have on my car has them seperate to but they are called starters by hanabi......but yes ignitors same thing.
Old Nov 23, 2004 | 08:40 PM
i never knew one spec of dust could be so dangerous
Old Nov 23, 2004 | 10:04 PM
mikeI302k's Avatar
i meant that hypothetically just to say be carefull with the bulbs they arent that easy to blow but easy enough.
Old Nov 24, 2004 | 06:00 AM
o ok. that makes a little more sense
mclasser
22
Nov 12, 2020 01:58 PM
maxinout93
Oct 31, 2015 02:04 AM
Vistance
Sep 17, 2015 05:17 AM
Hdnseek
Sep 9, 2015 05:55 AM
