How to Chang Fog Lights on a 96 I30t
Old Dec 21, 2004 | 08:47 AM
Redstone's Avatar
Does anyone knows how to change the foglights on a 96 Infiniti I30t. If anyone has done this before or has access to a repair manual you help will be appreciated.
Thanks Guys!!
Old Dec 21, 2004 | 09:06 AM
infintishock's Avatar
I don't have a manual or anything, but I switched out the foglights on my I30 a while ago. It is kind of hard to do it when the car is flat, so if it is possibly to safely lift the front end somehow, whether it be by jacking it up or driving onto a ramp, I'd suggest that. I also needed a socket set because there is a piece of plastic underneath that protects the area, and it is held on by bolts I believe. Once you reach the area inside, taking out the old bulbs and putting in the new ones is pretty much like changing your headlights.
Someone feel free to correct me if I missed anything, I did this about 7 months ago so I may have forgotten.
Old Dec 21, 2004 | 11:07 AM
queenambeach's Avatar
nah you're right. it's a real pain if you don't have the car on a lift or jacked up.
Old Dec 21, 2004 | 06:39 PM
anton9881's Avatar
Step:
1. Jack up the car.
2. Engage parking break
3. Unscrew the plastic undercarriage protector
4. Locate the foglight bulb
5. Undo the metal spring holding the bulb in place.
6. Disconnect the wires.
7. Put in new bulb
8. Connect wires.
9. Put the metal spring back in.
10. Screw the protector back in.
11. Disengage parking break.
12. Unjack car.
*EDIT* Be very careful not to apply excessive force to the plastic protector screws. I broke 3 of mine because they were practically rusted through. I would just recommend buying new screws and replacing the old ones while you are doing the swap.
vingodine
45
May 21, 2016 12:46 PM
EuroDriver
Sep 14, 2015 06:08 PM
Viralkill
Aug 17, 2015 10:54 AM
Viralkill
Aug 16, 2015 05:09 PM
98nismomax
Aug 13, 2015 12:44 PM
