Fog light not working.
My fog lights are not working resentrly. So I opened up to see if the lamps are bad, but they were good. I also tried changing the fuse, but whenever I put another one in, it just pops(gets burned).
In my opinion it's the wires. What do u guys think?
You need to take it to a shop. My guess is that some wire has grounded itself out some how and is causing the fuse to constantly blow.
You will spend hours, if not days chasing the **** around. Have a shop find the problem and then decide if you want to fix it yourself.
well if you wanna save yourself some money, and do a tiny bit of trouble shooting, you can take out one bulb and then the other to see which circuit is bad. if the circuit cannot be completed on the bad side the fuse wont blow, so you can see if it one or both, and when you find out which one it is, just take out your fogs and look at the wiring, something may have cut it down in that area, if you cant see any problems from there then take it to a shop, it might save you some money.
The Frye
Sep 2, 2021 11:03 AM
fastcarny
Oct 6, 2015 10:42 AM
-ReLLiK-
Sep 8, 2015 12:02 PM
