Headliner
Old Apr 18, 2005 | 06:58 PM
SuBXeRo's Avatar
Headliner
and of u take it down? i have a rattle/buzzing noise, like right baove the dome light area, so i was wondering if any of you have ever taken it down, or knowe whats causing this noise
Old Apr 18, 2005 | 07:00 PM
MetaOrbit's Avatar
Got Projectors?
My girlfriend's 4th gen has the same noise in the same spot. Haven't had the time to look at it closely though.
Old Apr 18, 2005 | 07:23 PM
HomerMAC's Avatar
Donating i30 Owner
yea i hear a little thing once in a while.. and i cant stand things that shake or move aroudn int he car.. im waiting till i get some time to get some new retension clips etc for the door pannels.. so i can put everything down... tight.. i hate things that move unless its supposed to move...
im also Obsesive compulsive... so.. yea.. im weird. but things moving in teh car that arnt supposed not GOOD..
Old Apr 18, 2005 | 07:33 PM
SuBXeRo's Avatar
ummmmm i cant stand it, i havent had a radio for about a month, ive gotten to know every rattle in my car very well, i happen to be ADD, although i dont have it bad, lil noises like this drive me insane.
Old Apr 18, 2005 | 09:21 PM
dontouchmymoney's Avatar
Is your rattle near the dome light when the sunroof sunshade is open? B/c i noticed this in mine too and it has something to do with the shade b/c when i close the shade the buzzing noise comes closer up to the front. It drives me crazy lol someone has to know how to fix this.
Old Apr 19, 2005 | 05:51 AM
HomerMAC's Avatar
Donating i30 Owner
wow good to knkow im not the only one.. my friend tell me how weird i am when she come to school with me... cuase i get pisssed at the noise...
Old Apr 19, 2005 | 06:25 AM
Double E's Avatar
I can tell you all about how to pull that sob headliner down. (sunroof cables had to be replaced) I didn't have a rattle before or after but can probably tell you what it might be.
Just to make sure...There's an overhead maplight and a dome light. Your rattle is in the dome light (as stated), right?
I'm assuming you've pulled out the light and the dome light assembly to see if it was something simple. If not, do it. It removes with a phillips screw.
If that's not it, under the headliner, there's a wire that comes from the driver's side B pillar to the dome light. It doesn't have the best connectors holding it to the frame and some are even light adhesive and tape. That cdould be it.
Of, course in order to get to it, you're going to need to remove the headliner and that's no party.
I'll do a better write up on removing it (I gave one about a month ago or so in a thread, but it wasn't comprehensive) if you want to go after it, but for now, clean out your sunroof rails of all of the old grease and lay down some fresh stuff. Turn up the radio (if you have one) and ignore it otherwise.
Old Apr 19, 2005 | 02:42 PM
SuBXeRo's Avatar
i would but no radio right now. ill be like hitting stuff in my car and my frienfds are like "are you ok?" and im like "I HATE RATLLES, THEY ARE EVERYWHERE" for me the rattle noise doesnt really change position, it just like stops more so with the sunroof inside liner closed then open
Old Apr 20, 2005 | 06:06 AM
Double E's Avatar
Ok, so do you have a day that you can take to find it?
I'd love to tell you what it could be but honestly, there are up to 30 points of contact where a rattle you're finding could be happening. If you're punching things already, it sounds like your patience level is not very high. I strongly recommend an adjustment to patience with how you approach this repair if you really want to fix it.
There a LOT of little fasteners and clips that will futher aggrevate you in this process. (Damaging them will be evident in how everything gets re-assembled and if you break them, you'll be even more frustrated for tearing it apart in the first place.)
Just to give you a tickler of what to expect before you just fix your radio and "deal with it" here's a little sample of what you'll have to do.
Remove driver & pass sunvisors, and mounting hardware
remove rear view mirror
remove maplight & dome light assembly
remove both passenger & driver front seats. (that's right, both seats.)
Remove driver & passenger seat belt upper anchors
Remove A-pillar molding
Remove C-pillar molding
Remove all 4 oh **** handles
Remove Headliner by carefully breaking away the velcro and plastic clips that hold it to the roof and start thinking of how you're going to get it out the door.
Slowly work the headliner towards the front of the car and it will release from its clips near the back of the sunroof opening.
I should have removed my rear seat also to get it the headliner out the dirver's side passenger door but I didn't. I ended up creasing it some in the middle to bend it through but the damage isn't visible now that it's reinstalled.
Now that your headliner is out, you'll want to remove the rack system that the sunroof is on to clean it. ( I recommend purchasing the sunroof repair "Kit" from Nissan and a bottle of brake cleaner and replacing the sunroof cables while you have it apart.)
The brake cleaner will come in handy to clean up all the crap that has been building up for the past 10 years. (wear gloves, brake cleaner will rot away your skin).
While you have that stuff apart, you might as well vacuum/shampoo your carpet, turn both seats upside down and lubricate the mechanics underneath them, clean your headliner and the OS handles.
Had enough? I can give you more......(yes, there's a LOT more)
(BTW: The dealer will want about 1K to do all of this.)
Old Apr 20, 2005 | 03:40 PM
SuBXeRo's Avatar
wow thats soo much work, i mean i have taken my front seats out and the carpet liner to shampoo all of it that was a *****. Nah i have decent patience with this stuff, i just hate rattles and this kills the rattle for a lil while
Old Apr 20, 2005 | 05:57 PM
i30ds's Avatar
Armed and Dangerous
Pulling the headliner is HUGE PITA make no mistake...
Old Apr 21, 2005 | 08:36 AM
Double E's Avatar
i30 is right. I think I even used his info to do mine and it was still bad.
Not impossible though. It just takes some time and patience. At the end, you'll have a good feel for what it takes to build the interior and your rattle prob may be gone.
Organize the screws and assorted parts well for re-assembly if you do it though. I screwed up reassembly of the metal bracket that covers the sunroof motor and forgot to install the pop-up wind deflector on mine. It makes the headliner less supported near the sunroof switch, that's about it.
I have a plastic wind shade anyway so I didn't care, but still have the part lying around in the garage all the same.
spencerwh1
Jun 30, 2016 05:44 AM
vingodine
45
May 21, 2016 12:46 PM
jonreidhead
Jan 6, 2016 09:38 AM
13Maximasv
Aug 7, 2015 10:56 AM
SWEETSOUND2001
Sep 10, 2001 07:17 PM
