Horrible Gas Mileage!
Old Apr 21, 2005 | 09:04 PM
95gxe's Avatar
I have noticed that my I35 is getting horrible gas mileage. I just filled up yesterday and ran out over a quarter of a tank of gas already with only 88 miles of highway driving. Any tips on improving the gas mileage. My 95 Max got much better mileage that this '02.
Old Apr 22, 2005 | 07:38 AM
dr-rjp's Avatar
Yes. Do not judge MPG on the basis of your gas gauge alone.
Here's what you need to do (excuse me if it sounds too elemental):
In the evening, fill your gas tank. Do not top if off. Whenever the pump lever shuts off, stop filling.
Next, reset your trip odometer to zero. If you do not have one, or cannot access it, then read the mileage off of your odometer and write it down on a piece of paper. Put the paper in your glove box.
Wait until your tank is halfway between the 3/4 mark and E, and then, at the SAME TIME OF DAY you filled your car, fill it up until the lever shuts off.
Either read the numbers off of your trip odometer, or take out the slip of paper with your previous odometer reading and write down the current odometer reading. Subtract the smaller number from the larger.
Look at the gas pump and write down the # of gallons of gas purchased.
Divide the mileage by the number of gallons.
That is the most accurate way of measuring your gas mileage.
Old Apr 22, 2005 | 08:20 AM
Steel's Avatar
Hmm That's odd, my last fill up I average 22 mpg (math calc., not the MPG in the car) And that is with 80% city driving.
Steel's Avatar
by the way 88 x 4 = 352 miles on the tank.
That's not horrible, however on the highway it should be better.
Old Apr 22, 2005 | 12:35 PM
i30ds's Avatar
Armed and Dangerous
doesnt sound like your gas milage is bad at all. And do remember that your new 3.5 is larger and more powerful than your old 95 motor.
Old Apr 22, 2005 | 05:06 PM
95gxe's Avatar
[QUOTE=dr-rjp]Yes. Do not judge MPG on the basis of your gas gauge alone.
QUOTE]
Thanks for the tip. I'll try that one and see what it comes out to be. It just seemed to use a good deal more than the Max did.
Old Apr 22, 2005 | 05:08 PM
95gxe's Avatar
Yaeh I know. I mean I could certainly live with it. But it seemed like it should've been a little better. I wonder how much a Q45 would use if the I drank that much in one day.
Old Apr 22, 2005 | 05:09 PM
95gxe's Avatar
True - I hadn't thought of that. I guess I'll have to get used to it.
Old Apr 23, 2005 | 08:03 AM
Steel's Avatar
I would still try to figure out what it is, because if I'm doing all highway driving I'll get 480-550 depending on speed. (Per tank)
Old Apr 23, 2005 | 07:08 PM
dr-rjp's Avatar
Just a quick followup to why reading the gauge can be deceiving:
The 1/4 marker on your guage does not represent 1/4 of a tank. Why? Because when your gauge hits "E", you are not completely empty. In fact you should have at least 2 gallons in reserve.
If you ever were to run it completely dry, you would see that true empty is quite a bit past the "E" mark.
Old Apr 24, 2005 | 06:13 AM
95gxe's Avatar
It is definitely something to get a handle on because spending extra at the pump is not fun, especially at these prices.
Old Apr 24, 2005 | 01:08 PM
roofadoofalus's Avatar
i got a measly 17 mpg last time i filled up. i only have city driving though, and i only drive about 15 miles each day.
Old Apr 24, 2005 | 02:30 PM
95gxe's Avatar
Is it just a given that this model gets the mpg that it does? If it's common according to other guys that have the same sort of numbers then I won't worry about it. The truth is that it's used, so everything can't be perfect on it.
Old Apr 25, 2005 | 11:30 AM
dr-rjp's Avatar
I would bet that every other make of car gets worse gas mileage driving in Tampa city driving! :-)
Old Apr 26, 2005 | 03:36 PM
MetaOrbit's Avatar
Got Projectors?
I don't think you're too far off from what I and other VQ35 drivers are getting.
I know my girlfriend's 4th gen uses less gas than mine does on the exact same trip (following each other at the same speed, etc.).
Old Apr 26, 2005 | 05:04 PM
95gxe's Avatar
[QUOTE=MetaOrbit]I don't think you're too far off from what I and other VQ35 drivers are getting.QUOTE]
Yeah, I checked it today and it actually averaged out to be approx. 20mpg. That's not too bad considering that the bulk of the driving was city. On a seperate note I took it to the dealer today to fix the pulling to the right and they squared it away. So now it's straight and smooth. To be honest I like it more and more each time I drive it.
Old Apr 26, 2005 | 05:16 PM
MetaOrbit's Avatar
Got Projectors?
That's good. What turned out to be the source of the pulling?
SuBXeRo's Avatar
just to be a stickler here
<-----12 mpg
talk about not wanting to spend alot at the pump, HA
Old Apr 26, 2005 | 05:27 PM
95gxe's Avatar
I'm not sure exactly. I took it on Saturday and got an alignment and wheel balance. They also rotated the tires. When I left it was still pulling. So today they rotated the tires again and it straightened out. So maybe it's the wear on the tires that were on the front. They said the specs were still right on the alignment. So the only thing I could think of is the tires.
95gxe's Avatar
<-----12 mpg
Is that the first time that happened? Or did you get 12mpg before?
Old Apr 26, 2005 | 05:42 PM
SuBXeRo's Avatar
practically since i bought the car, i never rwally thought anything of it, until i was talking to someone and said i get like 150 miles for like 12 gallons, i never really did the math and they were like i get like 250-300 for that much i was like, uhhh something is wrong. So i replaced my knock and im awaiting results to see if its actually working
Old Apr 26, 2005 | 05:44 PM
95gxe's Avatar
Hopefully it picks up for you. That would be a lot of money saved.
Old Apr 26, 2005 | 08:11 PM
SuBXeRo's Avatar
telling me man, its alot after a while, ugg then i could finally save some money
mclasser
22
Nov 12, 2020 01:58 PM
maxinout93
Oct 31, 2015 02:04 AM
ef9
Oct 4, 2015 08:43 AM
