Checking ATF
Old May 2, 2005 | 02:08 PM
rLx77's Avatar
Checking ATF
How do I check my transmission fluid for a 2001 I30/Maxima? Do I need to warm the car up, and put it in Park and then check?
Old May 3, 2005 | 01:17 PM
i30ds's Avatar
Armed and Dangerous
Check your owners manual OR read the stickies in the maintenance- Fluids & Lubricants forum.
Old May 9, 2005 | 10:58 AM
dr-rjp's Avatar
You can check it either when it is warm or cold. The important thing is to have the engine running when you do...which means putting it into Park and engage the emergency brake.
There are two lines on the ATF dipstick -- one marked COLD, and the other marked, HOT. They refer to the temperature of the ATF. The manual suggests checking it at both times; i.e., once after just starting your car, and again, after you have driven your car for awhile (at least 5-10 minutes). The fluid line should be at or very near the corresponding marks.
maxinout93
Oct 31, 2015 02:04 AM
magiconthetire
Oct 26, 2015 09:03 PM
salty318
Sep 29, 2015 01:21 PM
dshinn
Sep 26, 2015 08:07 PM
zmcneely13
Sep 26, 2015 02:26 PM
