Headlight PROBLEM HID BULB POPPED
Old Jun 27, 2005 | 06:29 PM
NOCturnalI30's Avatar
Hay My frakin HID bulb poped in my head light and now i have glass all over the inside of my light. How do i get it out i was thinking of just taking it out and shaking out as much as i can or just heating it up and opening it again and cleaning it out. What you guys think i should do im stuck.
Old Jun 27, 2005 | 06:30 PM
KNYFE's Avatar
I'd heat it and open it. Then you will know it is all out and it won't be a future issue. I've done it with tails and heads, not to tough.
Old Jun 28, 2005 | 06:11 PM
how do i remove the headlight????
Old Jun 28, 2005 | 09:46 PM
KNYFE's Avatar
Not sure with the oem light but for the cefiros it is just a few screws...
Old Jul 2, 2005 | 07:49 AM
CreativeDesignz's Avatar
i dropped one of my city lights inside my headlight housing once i got one of those small detailing vacumms with the little attachments and it sucked it right out
Old Jul 5, 2005 | 07:34 AM
SYCEFIRO's Avatar
Once your remove the headlights you may consider putting about half of bottle of rubbing alcohols into the headlight housing to rinse out the shattered bulb/glass inside the headlight housing.
Did this about 1 month ago to replace a customer's headlight.
Open up the hood
Remove the top bolt
Turn your wheel to oneside to access to the inner fender
Losen the inner fender (the black parts) I think there are two screws at the wheel wall and two on the botton below the fog lights.
Then from the inner wheel fender wall, you can access to 2 bolts to lossen your bumper (on the side).
Now you can reach in to losen the bolt that's holding the headlights in.
SY
sycefiro@yahoo.com
Old Jul 5, 2005 | 07:53 AM
Thanks for the directions but i had figured it out. I used rubbing alcohol and it worked out nice. some pieces were literally glued on so i had to use my hook tool to pic it out. it worked out nice. thanks for all your help guys
The Frye
Sep 2, 2021 11:03 AM
MaxLife17
Jun 27, 2019 01:37 PM
minsbang
Sep 11, 2015 08:48 PM
MaxLife17
Sep 8, 2015 02:36 PM
