Ugh! Damn Thing Wont Start Again!!!!!!!!!!
Old Aug 14, 2005 | 05:02 AM
Dr.Monkey1313's Avatar
Well, my car wont start again! I replaced the battery last week, had the starter replaced about 4 months ago and now it's going back in the shop!
I don't think it's the alternator because my battery would have drained first and I would have noticed the headlights dimming here and there for a while before it just decided to stop working, I think. I hope it's the starter again because then it will be covered by the shop that installed it, but DAMN IT!!!!
When I turn the key, NOTHING AT ALL!!!!!!
OK, thanks for listening.....
Old Aug 14, 2005 | 01:54 PM
i30ds's Avatar
Armed and Dangerous
Doc,
If you get absolutely nothing, not even a click, then the problem is the ignition switch. Our cars are starting to get old and a lot of guys are having to replace it... including myself. I replaced mine just a few months ago when the same thing that happened to you happened to me. The car did start again after several attempts, but I replaced the switch anyways.
The part is $19 from everything nissan(or I believe $37 from local dealer) and is really easy to replace. All you need is a screw driver. The ingnition switch is located in the steering wheel column. All you have to do is remove the trim (which I KNOW you KNOW how to do because you did work on your gauges). The switch is located on the left side and is held in place by 2 screws and an electrical connector. It wont take you more than 30 min. to replace.
Good Luck!
Old Aug 14, 2005 | 06:43 PM
i30ds: Hey thanks! Now I have some hope! I had the car towed to a local shop this morning and used the early bird drop off there. I will let them look at it and then see what hey say. I am having them look at some other things while it is there anyway.
Well, I may go ahead and buy this ignitian switch anyway and replace it even if this is not the problem now. I really appreciate your help with this and will let you know whats going on.
Old Aug 14, 2005 | 08:11 PM
i30ds's Avatar
Armed and Dangerous
Sounds good.
Old Aug 15, 2005 | 09:04 AM
Double E's Avatar
Sweet! This forum rules! Now I know what to do when mine goes....
Old Aug 15, 2005 | 11:36 AM
Luigi38's Avatar
It might be the alternator, when my alternator went out, the new replacement went out after 2-3 months. Until now my alternator is still all good.
good luck
Old Aug 17, 2005 | 07:15 PM
Update! It was the starter AGAIN! Anyway, it did not cost me anything since it was only about 3 months old and they were the ones who put it in last time. PHEW!
I still am going to order that part and install it. Can't hurt!
Thanks everyone!
Old Aug 18, 2005 | 06:15 AM
SYCEFIRO's Avatar
Thanks everyone!
Email me.. I think I still have one. NIB
SY
sycefiro@yahoo.com
Maxboy23
Sep 4, 2015 06:04 PM
trungg86
Sep 4, 2015 04:58 AM
dcardello
Sep 3, 2015 11:44 PM
crazyespn
Sep 3, 2015 01:30 PM
