How to fix squeaky window?
Old Dec 28, 2005 | 10:31 AM
I30tx's Avatar
I have a 2000 I30t. My driver's side window squeaks really bad when rolling it up or down. There any quick fix for this?
Old Dec 28, 2005 | 11:06 AM
cefiro8701's Avatar
umm...buy a can of lithium grease spray...
take off the door panel...figure out whats making it so noisy and tighten and spray it with lithium grease...
Old Dec 28, 2005 | 01:06 PM
hasei's Avatar
日産
This is covered under TSBs
Door Glass (Front) - Squeak/Squeal Noise
Classification:
BT01-034
Reference:
ITB01-055
DATE:
August 28, 2001
2000-01 I30; FRONT GLASS RUN RUBBER SQUEAK/SQUEAL NOISE
APPLIED VEHICLE:
2000-01 I30 (CA33)
APPLIED VINs:
2000 MY vehicles: All VINs
2001 MY vehicles: built before: JNKCA31A81T036780
APPLIED DATE:
All vehicles built before: May 23, 2001
SERVICE INFORMATION
If an applied vehicle exhibits a squeak/squeal noise when the front door window glass goes up or down, use the following Service Procedure to resolve the incident, it it should occur.
SERVICE PROCEDURE
The following procedure applies to both front doors.
1. Determine the source of the squeak/squeal noise as follows:
A. Lower the front window glass(es).
B. Spray the window glass run rubber with silicone lubricant P/N 999MP-A3010 (or equivalent).
C. Raise and lower the window glass(es) several times.
^ If the squeak/squeal noise is gone, proceed with step 2 below.
^ If the squeak/squeal noise still exists, check for other causes of the noise.
2. Install the new front window glass run rubber(es) according to the "BT" section of the applicable Service Manual.
NOTE: Remove any debris (i.e., run rubber material, dirt, etc.) from both sides of the window glass surface, near the edge of the glass.
3. Raise and lower the window glass(es) several times to confirm the incident is resolved.
Old Dec 28, 2005 | 01:22 PM
brio_max's Avatar
Learning English...
I had absolutely the same problem with this,but after tinted the window,it suddenly stoped to squeaks. So,just tint it! z
Old Dec 28, 2005 | 03:30 PM
i30ds's Avatar
Armed and Dangerous
I love it!
Old Jan 13, 2006 | 08:09 PM
Transporter's Avatar
Okay I know this may show my limited knowledge but what exactly is a TSB as mentioned above? Is this something that the Infiniti dealer is supposed to fix for free? Like a recall notice?
Old Jan 13, 2006 | 09:24 PM
KRRZ350's Avatar
it's a Technical Service Bulletin, there for the techs at the dealer. How many miles are on your car?
Old Jan 13, 2006 | 10:33 PM
KRRZ350's Avatar
haha, wait. Are you kidding me? do you realize how simple of a fix this is???? Do it yourself that way you don't have to worry about the techs spraying silicone spray all over your seats or something
Old Jan 14, 2006 | 09:18 PM
Thats why I asked. If it was a free fix I would take it in. Since its not. I will just do it myself. I just bought some new headlights so I will just do it when i put those in.
gigabyte
Jan 6, 2017 06:05 PM
Fbana41
Aug 29, 2016 12:18 PM
pears
Sep 18, 2015 05:25 AM
