Service Engine Light Question
Old Jan 16, 2006 | 04:00 PM
Tigger's Avatar
My "Service Engine Soon" light came on during my trip to Vegas this weekend. I am guessing it's a sensor since the car is still running fine. On my Durango, I would just disconnect the negative terminal and turn the key as if trying to start for 15 seconds to reset the light. That didn't work on the I-30.
Is there an easy way to reset the light? I am currently trying to locate a parts store with a reader to check the code, but wanted to try to reset it first and see if it came back.
Any thoughts would be appreciated.
Brian
Old Jan 16, 2006 | 04:24 PM
naijai's Avatar
head to autozone and they will look it up for yu as per reset look in the 5th gen forum answer in there
Old Jan 16, 2006 | 04:35 PM
Tim96I30t's Avatar
If it is the same as my 96 I30 the panel near your gas pedal comes off, your ecu is there, a tiny screw on the left side sometimes covered in tape, turn right pause left pause a couple times, it will go off, next start. Check how to's to be sure, if it does not look like I described it is different.
Old Jan 16, 2006 | 05:29 PM
05redrex's Avatar
Try this... use a second hand
http://www.technosquareinc.com/350reset.htm
Old Jan 17, 2006 | 11:09 AM
Tigger's Avatar
Tried the procedure from the 350 reset but couldn't get it to work. Went to Autozone and pulled up the code. P0160 Rear O2 Sensor High Input (Bank 2)
Reset the code and will see if it goes away. If not, I will replace the sensor when I get back to San Diego.
Thanks for the assistance everyone.
CorollaULEV
30
Aug 9, 2021 08:11 PM
Justinmc760
Aug 23, 2015 03:10 AM
maxinout93
Aug 20, 2015 02:17 AM
Flores94
Aug 11, 2015 12:53 PM
bassmann
Aug 3, 2015 07:53 PM
