questions about serpentine/PS belts
Old Mar 22, 2006 | 06:35 PM
flipinstyxs's Avatar
I had my belts changed out at this place called brakes plus here in colorado while i had my alignment done. The job for replacing the belts was a shade over 100 bucks but due to the crazy weather and time constraints from school, I submitted and gave them the go.
after they replace my serpentine and power steering belts, the engine from the inside of the car seems to "woes" when in drive and at idle. This "woe-ing" sounded suspicious to me so I took it back 15 minutes after i drove it off there lot. I told the guy that the "woe" sound wasnt there before but now after they change the belts out its there and can definitely be heard when the car stereo is off. the guys checked it and said that its my bearing?? WTF is that all about?
I'm hoping that a can of belt spray from a local pepboys shop would help do the trick to quiet the belt "woe" noise sound. If not...what shall i do guys?
Old Apr 3, 2006 | 03:59 PM
i30ds's Avatar
Armed and Dangerous
Did you even check your belts? What "bearing" is your mechanic referring to?
Old Apr 4, 2006 | 08:12 AM
00i30T's Avatar
Might be too tight or too loose!
Old Apr 10, 2006 | 05:15 AM
Adrian112597's Avatar
Adrian
I agree, just play with the Tensioner nut, i'd loosen it a little first (not too much) then start the car. See how it sounds. If not then go the other way.
trsandrew
Apr 8, 2016 06:45 PM
Unclejunebug
Apr 2, 2016 05:42 AM
doctorpullit
Mar 29, 2016 11:08 AM
Kyle Lee Cleveland
Sep 28, 2015 09:01 PM
Socalstillen
Sep 26, 2015 12:01 PM
