Easy alternate fog rewire
Old Apr 17, 2006 | 11:56 AM
below90hz's Avatar
I found an old thread here that redirected me to this link:
http://www.innerbean.com/housecor/fog_rewire.html
It seems to me that splicing into the tail lamp would be MUCH easier than snaking down to the side marker. Has anyone rewired using this method? I ask because step 9 says to splice into the red wire with green stripe and silver spots, but I assume since it is directions for Max rewire, the wire for our infiniti's will be different. If anyone has used this method of splicing, could you please tell me what wire from the tail (or similar) relay I should splice into?
Thanks for any help.
Old Apr 17, 2006 | 01:36 PM
NewLoveI30's Avatar
Why not just splice into the city bulb instead?
If you have an A33, you will splice the pink wire with green stripe (I think it's green) to the red wire going to the city light bulb. Pretty easy.
Not sure if the A32 is the same.
Old Apr 17, 2006 | 02:29 PM
StL I30's Avatar
That's how I did it. Pink wire with some color stripe like NewLove says to the same wire shown in that write-up for the brake lights. It'll have the same effect whether you tap into the city lights or the brake.
Old Apr 18, 2006 | 05:15 AM
below90hz's Avatar
Cool, I just didn't want to have to snake wire down to the side marker and take it out blah blah blah. I don't know why that method is listed as an answer in the FAQ. Seems like splicing in right at the fuse box would be the best way to go. Anywho, thanks for the replies.
Old Apr 18, 2006 | 06:21 AM
bi30's Avatar
I did the same thing pink wire stripes.
http://pg.photos.yahoo.com/ph/csarjo...53as,1%253af,0
trsandrew
Apr 8, 2016 06:45 PM
mpbclutch33
Dec 26, 2015 11:11 AM
trsandrew
Oct 25, 2015 02:47 PM
Calabar
Oct 5, 2015 09:57 PM
