Sunroof Problem: Tilt up and down works, but sunroof won't slide back
Old May 12, 2006 | 10:10 AM
Colossus's Avatar
I also posted this in the 5th gen thread.
My sunroof tilts up and down, but doesn't slide back. I can't find a sunroof fuse.
It stopped working when my brother installed a remote start in my car, but I'm not sure if it's related.
Old May 12, 2006 | 10:17 AM
Dr.Monkey1313's Avatar
I;m not sure if it's related either, but I had this same problem in my 96 I30. I posted the issue and fix on my cardomain page. Check it out and let me know if you have any further questions. I think it is on page 3 or 4 of my cardomain page. Hope this helps. http://www.cardomain.com/ride/796084
Old May 12, 2006 | 10:46 AM
Colossus's Avatar
All I had to do was look in the manual and follow the sunroof reset/relearn procedure. I had to hold the "tilt down" button for a few seconds and then the slide started to work again!
Old May 12, 2006 | 07:23 PM
Wow, I wish all of my car problems could be that simple! LOL
Old May 15, 2006 | 12:42 PM
Double E's Avatar
No Kidding! My sunroof cable broke & 6 hours later, after the seats came out, headliner was pulled and the entire assembly was repaired, I was back in business.
What a PAIN!!!
It's all good though. If that (and a starter) is all I've done to it in nearly 10 years, sign me up!
Old May 15, 2006 | 01:38 PM
sleeperI35's Avatar
Colussus,
The sunroof reset is easy as pie and it usually happens after you disconnect the battery cable...
Make sure the switch is slid to the closed position
hold the tilt up button for 5 seconds until sunroof is completely tilted up.
Hold the sunroof tilt down position button closed until the sunroof is completely closed and HOLD for another 5 seconds.
Try sliding the sunroof completely back SLOWLY (we have that lever button that slides back in "phases" so slide it back one phase at a time. Hope this helps..alot of I35 owners report the same problem. Should help fix the issue.
Old May 15, 2006 | 01:39 PM
sleeperI35's Avatar
Also while the track is exposed, spray some "grease" in the track.
Old Aug 4, 2011 | 10:50 AM
IanMasterson's Avatar
Thanks for the input on resetting the sunroof - I will let you know if this works as I have the same problem with a 2003 SE MT, after battery was replace.
Old Apr 29, 2012 | 04:30 PM
Brockster's Avatar
Thanks for the tip guys! My sunroof is now working properly.
Old Mar 27, 2018 | 06:52 PM
98Marxima's Avatar
Wish I had a sunroof. If one had all the parts, how hard would it be to install One?
jerrod99_se-l
Aug 27, 2015 08:27 PM
maxinout93
Aug 16, 2015 07:25 PM
BobMax
Aug 15, 2015 12:35 PM
Flores94
Aug 13, 2015 01:17 PM
kenc15
Aug 5, 2015 08:29 AM
