How to get parking/running light harnesses in new Cefiro headlights??
Old May 27, 2006 | 01:05 PM
af200sx/se-r's Avatar
Is there some kind of trick on how to get the corner harnesses in???
I've been searching for on hour on the net and can not find a solution. Anyone???
Old May 29, 2006 | 01:03 AM
SYCEFIRO's Avatar
I know you are always searching for the answers for the way things would work or fit into the products that you are selling. Please do your homework and researches. Try checking with your supplier. Or you can email me if you like.
Your supplier supplies the after market headlight housing, so to cut down the cost, they do not include the harness that would fit (TDM or JDM) housing.
Two ways you can do it:
1. Ask your supplier to supply those to you so that your buyers can simply splice the wires to the OEM USDM harness to run it. The advantage is that your customers will NOT run into water problem
2. The harness from USDM Maxima/I30 is not the same as the one's that fit these aftermarket housing. You can ask your customer to either enlarge the holes or cut off/shave off the OEM harness from their cars. The disadvantage is that they might run into water problem when it rains.
Feel free to email me if you have any more questions.
SY
sycefiro@yahoo.com
Old May 29, 2006 | 11:06 AM
thanx for the help
vingodine
45
May 21, 2016 12:46 PM
umnitza
Sep 1, 2015 01:03 PM
KristyKarina
Aug 23, 2015 09:53 AM
Viralkill
Aug 17, 2015 10:54 AM
Viralkill
Aug 16, 2015 05:09 PM
