Question about A33 Clear Side Markers
Some people have had trouble with getting the rear to fit. I only installed the fronts so I can't comment on that issue directly.
There are a couple methods to get the front to fit right in the FAQs.
And they won't flash. They stay lit continuously when your park/headlamps are on. And they'll light up whatever color bulb you put in there... I put amber.
I had no problems installing the fronts, never did the rears. For the front, instead of splicing wires, I simply modified the tab slot in the new clear corners with a simple kitchen knife. The plastic is relatively soft, i only needed to widen one of the tabs. I will be obvious once you look at them.
vingodine
45
05-21-2016 12:46 PM
Cant_Get_Ryte
08-28-2015 06:41 AM
