2002 I35, Odor after AC is off
Old Jun 21, 2006 | 03:00 PM
osetleo's Avatar
Guys,
Do you have suggestions on the procedure of odor removal (I guess mildew) from the vent system. When AC is off the first several minutes the smell is bad.
Thank you for your ideas.
Old Jun 21, 2006 | 03:27 PM
n3985's Avatar
大陆弟弟
Change your in-cabin filter, located in glovebox.
Old Jun 21, 2006 | 03:34 PM
osetleo's Avatar
Thanks, I read the other posts that it does not actually helps to remove the odor. I think the odor is from the mildew, where moisture is. Did you have the odor that you actually eliminated by replacing the cabin filter?
Old Jun 21, 2006 | 03:42 PM
n3985's Avatar
大陆弟弟
My AC actually does not have that strong a smell, and when it does once in a blue moon, I turn on the AC with NO recirculation and it's gone.
Old Jun 21, 2006 | 08:50 PM
i30ish's Avatar
is it better to use recirculation for AC. I've noticed it's cooler and fan speed is faster when i use it.
Old Jun 21, 2006 | 08:55 PM
n3985's Avatar
大陆弟弟
But then you recirculate moisture, moisture in the vents create mildew. Blowing fresh cold DRY air = no mildew, just start with fresh air, then recirculate after a few min.
Old Jun 21, 2006 | 10:37 PM
osetleo's Avatar
Do you have any techniques in actually removing the odor? I think as soon as mildew formed, it will smell, no matter what you do. The idea is actually somehow to kill the mildew, but I don't know any means to access the area (without dissambling half of the car). Does anyone now?
Old Jun 22, 2006 | 08:50 PM
BlueC's Avatar
wat
A nice trick is to run Lysol through the induction vents.
1) Grab a can of your favorite Lysol
2) Run the A/C at the highest fan speed
3) Position the can nossle at the induction vents
4) Spray until you are basically out of Lysol or when you feel its good
This should help kill off any mildew inside the vents. I do this every once and awhile to freshen up the vents and kill anything inside. Works like a charm and costs a few dollars.
Old Jun 26, 2006 | 07:57 AM
jdozier's Avatar
I found the following information on another website that may be of interest to you:
http://www.infinitihelp.com/Ownershi...AC%20Sytem.htm
Step 4 explains another possible solution to clearing out the odor.
mclasser
22
Nov 12, 2020 01:58 PM
maxinout93
Oct 31, 2015 02:04 AM
MaxLvr21
Oct 17, 2015 12:11 PM
09maxshawn11
Sep 30, 2015 10:28 AM
