?????????Engine light on??????????
Old Sep 28, 2006 | 07:51 AM
bi30's Avatar
Sup All,
Yesterday, i started my car and i noticed some shaking.
Shaked for 10 minutes. After that it went away but the "Engine Light Soon" came on. Didn't get a chance to go to mechanic yet to check computer but anyone have any idea? 2000 i30 with 48 K miles.
Friends are saying O2 Sensor. Saw it for $103.00, is that a good price?
Thanks for help.
Old Sep 28, 2006 | 08:07 AM
psk79's Avatar
same problem with me. starting 2 weeks ago. Goto Autozone and they will read the code for free. Mine started like that and its more frequent now. If I go over 60 mph it will start shaking and then it will be alright. If your code is P1320, whihc i think it is, then its a misfire. But we dont know which cylinder it is unless it give anotehr code like P0301 etc. The problem is that one of the six ignition coils is BAD. This is a well known maxima/I30 issue for 1999-2002.
I was told by the dealer to wait until one coil totally dies or change all the 6 coils. Their prices are f...... expensive. A coil for about $100 and total about 1000$. I found them online for 49$ each and we can change it in 1-2hrs. I am still waiting to see if it wil show up a cylinder code. I reset the check engine light 3 times but the only code I get always is P1320.
So I will wait a few more days and then I will change all the six. If yours is under warranty u can ask the dealer. Mine is a 2000 I30 with 78K miles. It was pinging a lot for last couple of months,...
Old Sep 28, 2006 | 08:10 AM
psk79's Avatar
ignition coils from ACDELCO are ~$55 a piece. The ones from Standard motor products inc are $49 a piece. The ones from courtesy nissan are $65 a piece.
Can anyone tell me if they are all the same or if anyone has ever used stuff from SMP??
Old Sep 28, 2006 | 09:12 AM
KRRZ350's Avatar
if the ones from courtesy nissan are nissan than get them, btw you totally hi-jacked this kids thread, but I geuss it's better than seing a bunch of pointless posts around trying to get to 15.
Ummm, well with the symptoms you described it's probably the o2 sensor however there is also a really good chance it could be a malfunctioning flex capacitor, I think you should check your trouble codes first, you can do it yourself with only a screwdriver and a service manual, you can even find how to do it on here or download the fsm on here for free, you do have a screwdriver right?
Old Sep 28, 2006 | 01:23 PM
i30ds's Avatar
Armed and Dangerous
Originally Posted by bi30
Sup All,
Thanks for help.
Check your codes first before anything else.
Old Sep 28, 2006 | 01:24 PM
i30ds's Avatar
Armed and Dangerous
Just spend the $50 for an igintion coil and be done with it then.
Old Sep 28, 2006 | 01:25 PM
i30ds's Avatar
Armed and Dangerous
Get the nissan brand... acdelco and smp are crap.
Old Sep 29, 2006 | 09:43 AM
bi30's Avatar
Sup,
Thanks a lot for reply.
I just came back from AutoZone, code - P1320.
Not sure what it is yet, will research.
How can i tell which ignition coil is bad?
Thanks again
Old Sep 29, 2006 | 11:57 AM
i30ds's Avatar
Armed and Dangerous
Sup,
Thanks again
I don't know how your car is running, but with the egine running (sh!tty), go around and unplug the coils one at a time. If the engine starts running like crap then replug the coil back and go to the next. When you unplug the bad coil, there will be no effect. Note that your coil has to be malfunctioning all the time for this method to work.
Old Sep 29, 2006 | 11:58 AM
i30ds's Avatar
Armed and Dangerous
Oh, the 5th gen forum stickies will be the best source to research.
Old Sep 29, 2006 | 09:45 PM
i30ish's Avatar
http://www.troublecodes.net/infinity/
Old Sep 30, 2006 | 06:06 AM
psk79's Avatar
I am having a similar problem. The coil isn't totally dead.hile driving all of a sudden I get the service light on and the car shakes for a few seconds and it goes off as I slow down.. its fine for a few days before it starts again..
P1320 says ignition primary. Is this definitely a coil issue? Can anyone help me?
I dont want to buy 6 new coils only to find out its not a coil problem.
I bought the tools and did a test run on removing all the 6 coils. I am no auto expert but I am able to pull them out and put them back in about 45 mins. THANKS to this great forum.. Now I am very confident I can do it.. If anyone can please confirm if P1320 is the coils, I will be very thankful.. These dont have the silver dot on them, which means they are probably the defective ones nissan had in 1999-2002.
Also on the front right most one I saw some more red lines on side than others. Some are just fine. Im thinking this is the bad one...
Thanks.
Old Sep 30, 2006 | 07:42 AM
psk79's Avatar
http://forums.maxima.org/showthread....29&mode=linear
Old Oct 5, 2006 | 09:41 AM
psk79's Avatar
Hi guys, just wanted to update you on the coil stuff. I got the new coils with grey dot on them and changed all my coils. It was easy. Remember not to loose the bolt that holds the coils. While I was changing hte rear right most coil, the bolt fell off and I couldnt find the damn thing. neither infiniti or nissan dealers have the bolt. Luckily my neighbor had a mangetic retriever tool and I was able to use it and get the damn bolt. So be careful when putting hte bolts on the rear ones.
I got autozone to reset my check engine light. Hopefully, the random misfire is gone now. However, this did not totally remove the damn pinging noise. It still rarely pings. Definitely not as bad when one coil of those coils is bad. BTW I found these genuine nissan coils for 280$ w/shipping (usps priority).
Old Oct 11, 2006 | 09:16 AM
bi30's Avatar
sup all,
FYI - Engine light came off all of a sudden, didn't do anything.
I went to mechanic and they ran the scanner and nothing came up, no codes.
Any comments?????
Old Oct 11, 2006 | 01:22 PM
i30ds's Avatar
Armed and Dangerous
it happens... don't be suprised if it comes back on later.
Old Oct 12, 2006 | 11:29 AM
psk79's Avatar
sup all,
Any comments?????
Once you got the P1320, you will get these misfire UNTIL u replace those ignition coils..
Old Oct 23, 2006 | 12:41 PM
C P Squared's Avatar
same thing in my 2000 I30, it shakes worst then it did before, its the censor, once i start to accelerate, my cars engine service starts blinking constantly
Old Oct 23, 2006 | 03:52 PM
MyBlue92Maxima's Avatar
hey i ran some code checks on my car and it's pulling i believe P0420 , which is a problem with the catalytic converter, what it actually is though, is the o2 sensors on bank1 arn't working properly, i was wondering what the best place to buy o2 sensors from would be? whats good brands for them? any help would be great thanks.
edit: probally should have mentioned it's a 2001 i30
Old Oct 23, 2006 | 07:48 PM
i30ds's Avatar
Armed and Dangerous
oem or www.oxygensensors.com
Old Oct 23, 2006 | 08:49 PM
mydecember1985's Avatar
Definitely not a good idea to drive it if it's BLINKING. Get that checked ASAP.
Old Oct 23, 2006 | 08:56 PM
I had this problem on my first I30. Apparently, it is quite frequent on 2000-2001's. If you go to the infiniti or nissan dealership, they will do an ECU upgrade that could fix the problem, otherwise, if that upgrade has already been done(dealership will be able to tell you.), you need a new O2 sensor, and possibly a new y-pipe. Me, being the idiot I am, had the nissan dealerhip replace it with OEM parts. 600 bucks for OEM y-pipe, 103 for O2 sensor, and 280ish for labor. JUST over $1K buckaroos to fix.
My advice: If you do in fact want/ need to replace the whole she-bang, buy an aftermarket y-pipe (half the price of OEM), and install it yourself. (less than 500 EASILY)
Old Oct 24, 2006 | 11:55 AM
theres an ECU upgrade? was it like a recall thing? is the upgrade free?
Old Oct 30, 2006 | 08:14 AM
bi30's Avatar
tried looking for DYI to replace ignition coils, found some stuff but no pics.
anyone know of any sites to replace coils, front coils seems easy but the rear coils seems a little hard.
any help is appreciated.
thanks
Old Nov 7, 2006 | 06:43 AM
bi30's Avatar
FYI, just changed the ignition coils, saved $150.00. Thanks to everyone, help was usefull.
I noticed 2 spark plugs were smelling like gasoline was on it and the other 4 were ok.
That's not suppose to happen, i don't think so.
Any comments.
Old Nov 7, 2006 | 04:43 PM
Chester86's Avatar
Howdy folks,
My first post here and I happen to have run into the same problem. Sad part is . . I just purchased my I30 yesterday afternoon. I guess I will run out to autozone tomorrow morning to see what is going on. This car runs very well and has excellent options . .big upgrade from a Toyota MR2 to this car. So far. . .I've been happy with it . . then again it hasn't been 24 hours yet. I'll keep you folks updated and look forward to being a part of the I30 family.
--Chester86
Old Nov 11, 2006 | 08:10 AM
I had the same problem, its your ignition coils got mine replaced and no more shaking
Old Nov 12, 2006 | 02:48 AM
Chester86's Avatar
Hmmm . . i noticed my car shaking a bit too. I thought it was my tires at first . . but might be ignition coils too??? Well, I am going to Autozone first thing in morning on Monday to see what the deal is. Does anyone have a link of how to replace the ignition coils or know a good website where we can purchase the replacements at?? Newbie here . .so I am looking to give my I30 a good cleaning with oil, trans oil, plugs, and new tires. Thanks!
--Chester86
Old Nov 12, 2006 | 09:41 PM
1ceman1's Avatar
I had this problem. The dealer changed 2 02 sensors. 600 dollars in total.
Old Nov 18, 2006 | 01:06 PM
mboy2abq's Avatar
ok, let's add this to the mix. Same problems as y'all are having on my 2000 I30, this morning it was cold outside and it ran really rough with the check engine light coming on. Went out to drive it as it warmed up outside and no signs of stutter or anything. O2 sensor or coils?
Old Nov 20, 2006 | 08:01 AM
bi30's Avatar
go to Autozone for a free scan. Let them give u the code, if it's P1320. It Coils.
Old Dec 26, 2006 | 05:43 PM
Rich96's Avatar
My Max started to idle like poo when I first start it up a few days ago. Scanned it today and its P0138 (O2 sensor, which that code has been on for almost 100K), and P1320. I'm guessing by reading this that I have a bad coil.
I did have a bad coil once before - but it gave me "cylinder 2 misfire" code which made it pretty easy to figure out which one to replace.
So I'd like to utilize your method to figure out which one I need to replace - but it doesn't run bad all the time. Any other way to figure it out?
Old Dec 27, 2006 | 07:27 AM
i30ds's Avatar
Armed and Dangerous
Try replacing the O2 sensors first, so the car is code free before you move on to the coils.
CorollaULEV
30
Aug 9, 2021 08:11 PM
magneto112
Sep 10, 2015 12:52 AM
Justinmc760
Aug 23, 2015 03:10 AM
maxinout93
Aug 20, 2015 02:17 AM
Flores94
Aug 11, 2015 12:53 PM
