Garage Door
Old Dec 6, 2006 | 02:15 PM
C P Squared's Avatar
Garage Door
Ive checked the owners manual and the DIY on here along with googling it and cant figure out how to program the garage door opener on the visor mirror.
Help will be much appreciated
Old Dec 6, 2006 | 02:34 PM
embraer's Avatar
Go back and check your owner's manual again. Programming instructions are on page 2-41 of the 2000 I30 manual.
Old Dec 6, 2006 | 02:51 PM
wow, i totally missed that, thanks alot
Old Dec 6, 2006 | 02:56 PM
One more questions, is the hand help transmitted, just a garage door opener?....sorry for such a stupid question
Old Dec 7, 2006 | 11:25 AM
Can anyone help a noob out plz?
Old Dec 7, 2006 | 11:30 AM
clayman88's Avatar
I'm confused by this...can you re-phrase it?
Old Dec 7, 2006 | 01:22 PM
leeI35's Avatar
G37S > I35 > UR Max
ZOMG -
Pick up your garage door opener (hand held device) and take it to your car. Point the transmitter to your sunvisor.
Choose a button you want to use on the homelink device to open the garage door.
Hold down that button and the open button on your garage door hand held transmitter.
When the led light on the homelink blinks very fast, that means the code is has been entered.
Hit the homelink button again to see if the garage door opens/close.
YOUR DONE.
Repeat again for the other doors if you have more than one garage door.
It took me literally, 45 seconds to program both of my garage doors on my home link. Good luck.
Old Dec 7, 2006 | 02:08 PM
^ Thanks alot
But one more question, do i do just what you said, or still parts from the manual, like the part when you have to hold the two outer buttons so it deletes the factory code?
Old Dec 7, 2006 | 02:17 PM
Weeble1's Avatar
The Whistle go WOOOOO
^ Thanks alot
yes, That's what I did. There is no harm in doing it.
Old Dec 14, 2006 | 03:16 PM
Ok guys, me and my friend did everything you said several times he even has the intructions that come with the car from his mom's car..anyways, weve tried and tried and tried and it hasnt worked, we tryed all three buttons using the exact instructions. Could it be that my cars a 00' and his moms is an 01'?
Old Dec 14, 2006 | 03:27 PM
clayman88's Avatar
I know my garage door opener has a learn button that you gotta push. Once you push it, you've got like 30 seconds to use a remote. During that time the door opener remembers any signals that it receives.
Old Dec 14, 2006 | 04:57 PM
MaximaExposure's Avatar
I believe you have to hold the button on the visor and the button on your transmitter for quite a while until the red LED on the visor blinks rapidly (or slowly? I can't rememer), and I think it's different for garage door opener's with rolling codes. Just read the instructions from the owner's manual carefully, and follow it word for word.
embraer's Avatar
The visor transmitter is not compatible with ALL brands of garage door openers, so it could just be that you have one of those incompatible brands. I have this same problem. I know the problem is with the garage door opener as my old Nissan had a visor transmitter and it did not work, my current Infiniti transmitter does not work, and my wife's Toyota one does not work either.
Old Dec 15, 2006 | 11:59 AM
teksurv's Avatar
This is likely the key. Try it.
Old Dec 15, 2006 | 03:08 PM
MetaOrbit's Avatar
Got Projectors?
Yeah, I've found garage door openers that are 10 years old that have the rolling code feature.
Pretty much every single one I've programmed had to use the learn button the unit itself.
Old Dec 16, 2006 | 08:20 AM
i have one of these
i googled it and cant find a list of brands its not compatible with.
Old Dec 16, 2006 | 08:34 AM
MetaOrbit's Avatar
Got Projectors?
Intellicode.
It's rolling code. Did you do as the directions said for rolling-code garage door openers?
If not, that's your problem.
Old Dec 16, 2006 | 10:27 AM
nvm i see where your getting at, i will go and follow the instructios for that one
Old Dec 17, 2006 | 07:56 AM
ac3 b00gi3's Avatar
l3eeI35 where did u get that front bumper ??
REDinLV
Aug 15, 2024 12:30 AM
trsandrew
Apr 8, 2016 06:45 PM
magiconthetire
Oct 26, 2015 09:03 PM
trsandrew
Oct 25, 2015 02:47 PM
BobTX10
Oct 7, 2015 08:43 AM
