re-attach rear view mirror?
Old Jan 15, 2007 | 03:06 AM
Obespalov's Avatar
In a drunken haze, some girl knocked off my 96 I30 autodimming rear view mirror last night. I've been trying to re-attach it but I can't seem to get some big metal screw into some strange looking metal paperclip looking thing which is attached to that the bracket (?). Also, there was some rubber cylinder piece which was touching the windshield and I have not idea what it was for or whether I need to crazy that thing back on?
Help?
Old Jan 15, 2007 | 08:46 AM
Double E's Avatar
rubber thingy
I'll try to get a look at mine today for you about the screw but the rubber thing just sits between the windshield and the post that drops down from the bracket.
It is not glued in from the factory and is probably only there to limit vibration to the mirror. It gets mounted on the little protrusion on the back of the post and just compresses against the windshield.
Hopw you had fun last night.....
Old Jan 15, 2007 | 11:26 AM
teksurv's Avatar
It sounds like your mirror is the same as on my Z. The trick is to slide out/remove the metal clip, attach mirror to winshield, slide retaining clip through/around the big metal screw. Replace plastic cover and done. The rubber cylinder is for vibration dampening, not a real biggie.
Old Jan 15, 2007 | 12:49 PM
Obespalov's Avatar
thanks, i got it re-attached.
matts95max
Apr 23, 2025 10:44 AM
GregL65
Jan 17, 2020 08:01 PM
flu2000
Sep 8, 2015 02:23 PM
