Whats the rec. mileage for a water pump
Old Jan 24, 2007 | 01:59 PM
Brudda Bob's Avatar
replacement? MY 2K I30 has 122K and I bel. the waterpump is leaking. Also what else should be replaced if this service is being done. I'm having the P/S AC belt, thermostat and crankshaft seal belt replaced along with the water pump. Any other suggestions would be appreciated.Thanks
Old Jan 24, 2007 | 02:26 PM
i30ds's Avatar
Armed and Dangerous
All that sounds good but what is a "crankshaft seal belt"??
Old Jan 24, 2007 | 05:52 PM
Brudda Bob's Avatar
Ahh "that" my friend is something that came ONLY on MY EYETHREEO. The more experienced call and realize it's a mistake. Others, they question.Thanks
Old Jan 25, 2007 | 04:26 PM
i30ds's Avatar
Armed and Dangerous
I am aware it was a mistake, and I am not asking because I don't know what it is, I am asking what you ment by that (i.e. clarification)...
Old Jan 28, 2007 | 06:29 PM
KRRZ350's Avatar
wouldn't even bother with the crankshaft seal unless it's leaking bad and the outer timingcover was off, you don't need to take the main outer cover off to do the waterpump.
Old Jan 29, 2007 | 02:08 PM
i30ds's Avatar
Armed and Dangerous
I can't see how replacing the front main would be something to do during a water pump replacement. Its not one of those small items that gets replaced "while you're in there"... like belts or a t chain tensioner. Basically, the y pipe, tranny, axles, clutch/ flywheel (or t converter/flexplate), and the main oil pan have to be removed in order to PROPERLY replace both the rear and front main seals.
Old Jan 30, 2007 | 08:42 AM
KRRZ350's Avatar
the front main isn't like the rear main, it's just a conventional seal in the outer timing cover, no upper oil pan bs to deal with, there is still a front oil pan seal though and if anything that one will leak well before the front crank seal, but everything else i30ds said is spot on, the main oil-pan seals (front and rear) and rear-main is a pita job for sure, and regardless the front crank seal is still alot more extra work than just doing the waterpump
Old Jan 30, 2007 | 08:50 AM
KRRZ350's Avatar
hey did you ever end up doing your buddies? I did another one recently when I did a 5-speed conversion........... DON'T FORGET TO REMOVE THE DIPSTICK!
Old Jan 30, 2007 | 03:46 PM
i30ds's Avatar
Armed and Dangerous
Looking in my FSM, I see what you're saying about the front main.
Old Jan 30, 2007 | 03:48 PM
i30ds's Avatar
Armed and Dangerous
Naw... He's thinking bout pulling the motor and dropping in a DEK or 3.5.
Miket2006
Mar 1, 2021 03:55 AM
salty318
Sep 29, 2015 01:21 PM
salty318
Sep 28, 2015 07:22 PM
