How to I aim my non-HID headlights?
Old Apr 28, 2007 | 09:01 AM
thisasian's Avatar
So... how do I do it? I saw something in the FAQ about Cefiero, but nothing for just the i30... I'm prolly just ignant.
Old Apr 28, 2007 | 10:24 AM
MetaOrbit's Avatar
Got Projectors?
Measure the height from say the center of the low-beam reflector to the ground.
Then shine your headlights on wall 25 feet away (make sure you're on a level surface).
You want to aim your headlights such that the light drops 2.1-2.5" from the height you measured earlier.
So, if your headlight height is 25.5" from the ground, then the light on the wall (the cutoff) should be 23-23.4" high.
And I'm not sure if the halogen headlights have a flared kind of cutoff:
But if they do, you're going to want to measure the height of the lower end of the flare (on the left).
Old Apr 28, 2007 | 11:01 AM
StL I30's Avatar
There is a white **** on the back of the headlights. Turn one direction lights aim up, turn the other lights aim down. Than just aim as Meta has described.
We do have the flare so you will want to use the lower left side of the beam pattern for your height adjustment.
Good luck.
doctorpullit
Oct 28, 2019 10:58 PM
trsandrew
Apr 8, 2016 06:45 PM
knight_yyz
Nov 1, 2015 01:34 PM
trsandrew
Oct 25, 2015 02:47 PM
Noela
Sep 26, 2015 08:22 AM
