98 fog light removal
Old Jul 30, 2007 | 08:45 AM
maximus_pr's Avatar
i did a quick search with no luck on how to remove 98 fog light to replace the bulbs need some help
Old Jul 30, 2007 | 09:48 AM
maximus_pr's Avatar
nevermind just found out how to but let me tell you is not as easy at it may look specially if the bolts holding the cover under the bumper are rusted like mine it took me more to take them out and replace them with some new bolts than to replace the bulb itself
one more thing i just put 100w like my cousin but needed to cut a small nip than the 55w don't have so far he using the regular sylvania 100w for almost a month without a problem anyone else using it
Old Jul 31, 2007 | 05:59 AM
OnEBadAsSi30's Avatar
Use periods. I got a headache. I give that wiring harness no more 2 months before it burns it up. With more wattage you're asking for more amperage that the little 18 AWG wire can't handle. Either you will blow the fuse and/or the wiring will get so hot it will melt the insulation. You don't need to take out the foglight housing to switch out the bulbs. Use PB Blaster for the rusty bolts. I purposley broke mine off. Drilled the bolt out then tapped in new ones. I've replaced my foglight housings 3 times now becuase of road construction.
Old Jul 31, 2007 | 08:51 AM
maximus_pr's Avatar
is this your own experience or thats a guess
oh one more thing i just checked and if it is true is a 18 awg then it should be good for 16 amps and if i'm right
100W/12v=8.3 amps
Converting Watts to Amps
The conversion of Watts to Amps is governed by the equation Amps = Watts/Volts
For example 12 watts/12 volts = 1 amp
Correction there is an amps x 1.1 factor when using dc(car) power so exact amps should be 9.13
the fuse is a 10 amps so it should be fine again someone correct me if i'm wrong
Old Aug 1, 2007 | 12:12 PM
queenambeach's Avatar
You don't need to take out the fog light housing to change the bulbs
Old Aug 1, 2007 | 09:07 PM
maximus_pr's Avatar
thanks! i did not remove them what was hard was the damn bolts holding the cover underneath but some PB and lots of patience helps
The Frye
Sep 2, 2021 11:03 AM
mvm062
Nov 30, 2020 09:00 AM
Maxima30
Sep 7, 2015 06:13 PM
MidnightMaxima_22
Sep 6, 2015 01:18 PM
