Ignitition Coil Help
Old Nov 27, 2007 | 07:16 AM
below90hz's Avatar
Took my 2000 I30 to a nissan dealership (closest Infiniti is 60 miles away in another state) after it started misfiring and it kicked out the dreaded "bad coil" code. Dealer wants $300 to replace JUST ONE.
Questions:
1) Dealer says there are only 3 coil packs for the 2000 I30, is that correct?
2) I've got moderate mechanical skillz and my bro is good at this stuff, so this is something we should be able to replace ourselves right?
3) Where do I find a good deal on coil packs?
Any help is appreciated, thanks guys.
Old Nov 27, 2007 | 10:11 AM
dineth00i30's Avatar
HOW DO U KNOW IF UR CAR IS MISFIRING?
Old Nov 27, 2007 | 10:41 AM
oldngivout's Avatar
Willing to learn
http://forums.maxima.org/showthread.php?t=545866
Old Nov 27, 2007 | 10:47 AM
below90hz's Avatar
Cuz it shakes like crazy and loses power and the RPMs jump around.
Old Nov 27, 2007 | 10:48 AM
below90hz's Avatar
Originally Posted by oldngivout
thanks
Old Nov 28, 2007 | 12:57 PM
ok well once wen my engine was super cold and i never drive it cold xcept this once and it shaked rite after 1500rpm so i stoped for few seconds and started to go and it didnt happen. but i always warm up the engine before i drive. do u think its the coils? ( also my MAF is bad).
Old Nov 29, 2007 | 10:03 AM
bi30's Avatar
sup man had the same prob. with the I30. easy to do by yourself. to be sure, go to auto zone to let them run the diagnostic test for free and let them look up the code.
check out everythingnissan.com for the parts. suggestion - buy all 6 and change them one time.
Old Nov 29, 2007 | 10:17 AM
brio_max's Avatar
Learning English...
Old Nov 29, 2007 | 05:54 PM
yeah the thing is tho my alternator gave up tuesday and the battery died and when i fixed it last night obiviously everything was reset so do u think the AUTO ZONE can get the codes?
Old Nov 30, 2007 | 01:19 PM
bi30's Avatar
you can try.
Old Dec 2, 2007 | 08:42 PM
you can try.
well i jus hit 80 miles on odo aftr bettery dyn and if im rite thats ab8 the miles it take for the car to get all the codes again so tomm afta school ima check.
Old May 8, 2024 | 05:24 AM
Dirtydoug's Avatar
Will the maxima coil packs work for the I30. Im having problems finding budget friendly coil packs
Old May 8, 2024 | 04:11 PM
below90hz's Avatar
Wow it's literally been 17 years since I started this thread lol. Anyways, yah iirc it's the same engine as the Maxima, the VQ30DE.
Old May 13, 2024 | 04:13 PM
wezmykat's Avatar
just go to rockauto for the best prices, but only buy OEM/made in Japan though
If you want to isolate the issue, just switch 2 packs from 2 cylinders, if the misfire code moves to the other cylinder now, bingo, if you're cheap just buy 1, if the other are fine why replace?
Old May 13, 2024 | 05:32 PM
Dirtydoug's Avatar
Im lazy. I just bought 6 new ones. I did keep the old ones. Its running 90% better after plugs/coils but still acts up a little
TallTom
57
Oct 14, 2025 05:16 PM
jmlee44
Oct 2, 2022 02:13 PM
howardis
Dec 11, 2019 06:10 PM
dshinn
Sep 26, 2015 08:07 PM
zmcneely13
Sep 26, 2015 02:26 PM
