Taking out front lights on A33 I30
Old Jun 9, 2008 | 04:04 PM
C P Squared's Avatar
I got the two front screws out of the front lights and unhooked it out of the white holder but there is something holding it in to prevent me from taking the whole thing out. I'm trying to take the orange dome out of the turn signal while taking puting the lamin-x I just got on teh fogs. Does anyone know where I can find a DYI to do it both of these correctly?
Thanks,
Chuck
Old Jun 9, 2008 | 05:02 PM
clayman88's Avatar
Are you trying to remove the plastic lense from the front of the headlight? If so, I believe you'll need to heat up the lense so that the glue softens and then you can pull it away from the housing.
Old Jun 9, 2008 | 05:04 PM
McSteve's Avatar
there is a third screw on the side and low of it. you have to go through the wheel well. remove the bolts of the plastic cover in the wheel well and then look straight up on the side. it is between the fender and some metal. Sorry if i am confusing
Old Jun 9, 2008 | 05:28 PM
If I heat up the lense do I still have to take out the whole housing just to get the orange dome out?
Sorry, I'm a car noob.
Thanks,
Chuck
Old Jun 9, 2008 | 05:48 PM
Also how do I go about taking the fog lights out? Do I have to take apart the whole bumper?
Old Jun 9, 2008 | 06:04 PM
essential1's Avatar
My axles cry for mercy...
No, just get under the car and peel back some of the plastic pieces under there. You can access all the screws you need to take out the entire assembly for both fog lights from there. Just get under there and look. It'll make sense when you see it.
Old Jun 9, 2008 | 06:47 PM
I just wanted to know if there was an easier why because my screws are rusting and stripped, I have to get a dremel tomorrow and grind them off....
carguy96
20
Feb 6, 2021 06:21 AM
beboski
Aug 16, 2015 05:23 PM
jomax14
Aug 12, 2015 11:49 AM
papo99
Aug 9, 2015 07:32 AM
kirkhilles
Aug 8, 2015 10:53 AM
