White Led's in Clock and HID's PICS
Where did you get them from? As mentioned by burgy, here are mine. I got them from superbrightleds.com. They look so much better in person. these are crappy point and shoot pics.
LED sidemarker shots
Interior lights
Finally, the clock
Also have the LED's in the Map lights but didn't take pics. The dome light is a 9 LED festoon. The doors are 4 LED wedge's, the Map lights are a single LED and the sidemarkers are 5 LED wedge. I love the soft white light these give off sooooo much better.
Interior lights
Finally, the clock
i got them from http://autolumination.com. is superbrightleds.com better?
Dose anyone kno which festoon I'm need to order for the map lights in the front and the climate and radio blulbs?
you can check http://www.sylvania.com/ConsumerProd...lacementGuide/
for all the bulb numbers etc. There are many options for each one so you will have to decide what you want. Dragongirl listed the ones we got for her car in terms of style but you may want more or less LED's in the different applications.
Autolumination.com should be decent?? I can get the actual bulb #'s from the ones we have if your interested....
What type of LED bulbs do you guys use for the bottom door light, map light and license plate, I am new to these so any links would help. I tried checking the LED sites but got lost
http://www.ddmtuning.com/products/DD...it-101-60.html
It says which bulb they replace, but which style you want depends on how bright etc that you want it....
for your 01 I30
http://www.sylvania.com/ConsumerProd...RG-Results.htm
As for the HID's, they are just 8K replacement bulbs in the headlights and I just put in 8K conversions in the fogs and they look sick!!
for your 01 I30
I did NOT do the license plate lights as I could care less if pepz see mine, but I used the single shot LED's in the Map lights and I would suggest you Don't, get one with at least three LED's. I also got a 3022-W9 Festoon for the Dome light and again I would say just get a W6 Festoon instead if you get the larger Map lights. The doors and side markers got 4 LED wedge bulbs. G/L
Would look like below:
http://forums.maxima.org/infiniti-i3...ight-bulb.html
Although you have more and brighter LEDs to choose from now.
Actually make sure you look for
Neo - Wedge LED Instrument Panel Bulbs Type A, B & C
(Note to choose the correct bulb, measure the diameter of the base)
Choose type B and whatever color you want.. I went with super white..
The install is really easy. I found it easier to turn the vents down and put my fingers in there and yank strait out
After that you will see 2 screws to remove the top trim. There is no need to remove the clock from its trim. Just turn it around and the bulbs will looks like 2 grey screws.. When you install the new leds make sure you try them out before you re assemble the dash.. There is a 50/50 chance they wont work the first time as the led contacts are polarity specific. If it doesnt work the first time just turn the bulb around.
After that you will see 2 screws to remove the top trim. There is no need to remove the clock from its trim. Just turn it around and the bulbs will looks like 2 grey screws.. When you install the new leds make sure you try them out before you re assemble the dash.. There is a 50/50 chance they wont work the first time as the led contacts are polarity specific. If it doesnt work the first time just turn the bulb around.I bought a 00 I30 two weeks ago and thought it was strange that the fancy analog clock didn’t light up. I went for the white LEDs and needless to say, now it’s the brightest thing in the dash.
Thanks!!
I’m also having the problem where the fuel gauge and speedometer lights are burned out.
Do you think its better to fix this or install white face gauges? (I haven’t located any yet)
I followed the above instructions and it worked out perfectly.
Thanks!!
Thanks!!
Knock on wood, mine haven't dimmed yet in my '01.
A33 I30's use bulbs similar to the maxima's. A33 I35's use the flourescent tube light.
From what I recall from the people with maximas that threw leds in the cluster weren't too happy with the angle of light emitted from the leds. They had brighter and darker areas.
The 2000 I30 also use the fluorescent tube for the dash. Mine has been getting dimmer and dimmer, and can barely see the speed and gas gauges now, especially when its cold out.
Wow, I cant believe this post I started is still around!
I came back to the forum to find out what type of bulb to use in the cornering lights and plate light.. Just so you know, the LEDs i put in the clock are still working just fine and so are my HID's! Im putting some new yellow bulbs in the fogs tomorrow since one burned out.. MY last HID project was on my new motorcycle
Im also customizing a cheap driving light to use HID and mounting under the headlight on my bike.. My Ninja is lit up like a Christmas tree!
Just some knock offs of the PIAA Ion yellow bulbs I used to use in my Maxima..I got them from autolumination.com for a couple bucks a piece.. They were the closest thing I could find to lexus yellow without getting a capsule.. Ill take pics once I get them done..
MaxLife17
Jun 27, 2019 01:37 PM
t6378tp
Sep 29, 2018 04:27 PM
