LED's playing tricks with me..
Old Jul 16, 2008 | 02:38 PM
Norkoastal's Avatar
Installed LED's into the tails (4) license plate (2), front lights (2), rear sidemarkers (2), dome, and 3rd led brakelight. All goes well after install.. Looks great..
A couple weeks back my HVAC display starts flickering when I apply my brakes.. This flicker makes it up to the nav screen.. WTF.. Today I hear a light/faint click sound everytime the brake is applied from around the shift console and notice my radio dimming when the brake is applied...
After that issue I have been swapping bulbs and adding load resistors to two of the 4 bulbs in the brakelights.. Im still experimenting with wires to tap but has anyone else had this issue? I know I'm a led feak, but ive only been adding these bulbs two at a time... It seems there might be a tipping point before the car freaks out.
Old Jul 16, 2008 | 09:27 PM
trent.davis23's Avatar
You will hear a click if the car is in park, pressing the brake unlocks the gear shift button. Its pretty loud though so that might not be it. I'm lost on the display dimming, sorry.
Old Jul 16, 2008 | 10:35 PM
Norkoastal's Avatar
I think thats the noise.. Now I need to swap all the stockers back 1 at a time to solve this mystery.
Old Jul 18, 2008 | 04:40 PM
AcuraLegend's Avatar
Just curious: how hard is it to replace the interior lights (the door & dome) with LEd's? I just replaced the clock LED's last night, and would like to do LED's throughout the cabin.
I'm an LED newb, I know that I will need a resistor, but that's about it
Old Jul 18, 2008 | 04:47 PM
OK.Eric's Avatar
Well it sounds pretty obvious that when the LEDs are activated, it's draining the battery voltage enough to cause other battery operated components to be affected as well.
Old Jul 18, 2008 | 05:41 PM
Norkoastal's Avatar
Hmm... I thought actually the opposite. The lack of draw trips the computer into thinking there isnt anything plugged in causing the madness I have been experiencing.. Tonight all the bulbs will be swapped to stock to test.
Old Jul 18, 2008 | 05:43 PM
OK.Eric's Avatar
Thats really the best test you could do.
Old Jul 18, 2008 | 07:08 PM
Norkoastal's Avatar
front 192 leds in headlights were the culprit... They were starting to melt and must have shorted something.. All is well so far..
Old Jul 18, 2008 | 08:30 PM
MetaOrbit's Avatar
Got Projectors?
Yeah, the LEDs in the headlights don't last long. Too much heat. LEDs in the license plate lights don't last long either...that's either heat or voltage spikes. Though my home-built license plate lights with in-line voltage regulator have lasted a long time now.
Old Jul 19, 2008 | 10:14 AM
OK.Eric's Avatar
Well thats good that you fixed it. I'm surprised because I thought that LEDs didn't generate much heat.
Old Jul 19, 2008 | 02:18 PM
MetaOrbit's Avatar
Got Projectors?
LEDs generally don't (though some LEDs do generate a great deal of heat), but in the headlights you also have to contend with the large amount of heat already being produced by low beams, high beams, running lights, etc.
doctorpullit
Oct 28, 2019 10:58 PM
trsandrew
Apr 8, 2016 06:45 PM
mpbclutch33
Dec 26, 2015 11:11 AM
trsandrew
Oct 25, 2015 02:47 PM
