So i bought a I30, seemed like a great deal....
Old Mar 6, 2009 | 06:55 PM
Kaane's Avatar
So i bought a 2001 I30 with 134,000 miles for $2700. The car would not start due to dead battery and idle issues. It also had a check engine light.
I knew it had a few issues, but I was hoping i could fix them relatively cheap.
Here is so far what i found and fixed.
Charged the battery, the car would start but not idle.
Had codes for Maf and IACV valve. Bought a new maf, car would run a bit better, but the idle was still crappy. Also the charge light was on, so found out the alternator was dead.
Started taking it apart to replace the alternator and both axles had CV boots totally ripped. So i bought 2 new axles, while looking at the front struts, both were leaking. So i bought 2 new struts.
2 days of hard work and I had struts installed, alternator replaced. Axles installed as well.
Started working on the idle issue, bought a new IACV, installed it, but it still doesnt idle and won't relearn. So i searched this forum and found that ecu can be damaged from a bad iacv valve.
30 minutes of cursing and busted knuckles had the ecu out. Open it up...... and 2 chips are blown and seconary damage on the pcb.
So now the question is, who knows a good place for cheap ECU's or a good repair facility?
Also when the car is running i can hear a hissing noise by the intake manifold, i sprayed some misty water on it, but i can't see any leaks. Could the noise be normal?
Old Mar 6, 2009 | 07:21 PM
pchau's Avatar
call daveb
Old Mar 6, 2009 | 07:45 PM
AceofSpds's Avatar
wat
www.car-part.com
Old Mar 7, 2009 | 06:48 AM
Kevlo911's Avatar
Kevlo for President
Ya car-part.com and ebay.
Old Mar 7, 2009 | 06:53 AM
oldngivout's Avatar
Willing to learn
Hissing is due to upper intake manifold gasket leak. You might as well fix that while you're at it. It will run a lot better when cold then.
After it's all fixed, either replace the ECU in the dealer parking lot or be prepared to tow it there. You won't be able to start the car at all with the replacement ECU, until is reprogrammed by the dealer with Consult.
Old Mar 7, 2009 | 06:54 AM
MaXiM@KiD's Avatar
MaXXiN
Auto or 5spd. Does anyone know if the 00 and 01 are the same? I know it's 3.0 but is did the egr or anything change? I'll PM this guy I know that had a 00 ECU he might still have it but I think it's 5spd...Also when you change the ECU you have to re-program the key
Old Mar 7, 2009 | 07:05 AM
oldngivout's Avatar
Willing to learn
He has an I30.
All 2000 I30 are auto, CA emissions.
Old Mar 7, 2009 | 07:16 AM
MaXiM@KiD's Avatar
MaXXiN
Maxima...err 5spd and fed spec too..sorry I couldn't be of more help
Old Mar 7, 2009 | 10:28 AM
Maxgig's Avatar
Keep a record of what you spend getting it properly road worthy. Once you're done you should have many miles of trouble free driving and you'll see that it was money well spent
Old Mar 7, 2009 | 01:47 PM
Kaane's Avatar
Anyone have the part number or picture of which manifold gasket goes out? While waiting for a replacement ecu, i want to tackle it.
Old Mar 7, 2009 | 03:06 PM
turbizzy's Avatar
Autozone also rebuilds ECMs for like 100 bucks. Might wanna give them a call.
Old Mar 7, 2009 | 11:06 PM
Kaane's Avatar
autozone rebuilds ECU's??? since when?
Old Mar 7, 2009 | 11:41 PM
Brianm0121's Avatar
ebay
Old Mar 8, 2009 | 11:07 AM
Kaane's Avatar
Does anyone know if a 2000 ECU will work in my car? Or are 2000 and 2001 different?
Old Mar 8, 2009 | 01:58 PM
turbizzy's Avatar
They rebuilt a customer's 1990 J30 ECM because he didn't wanna for out like a grand for a new one. I told him he could try that but no gaurantees from us it would solve his problem. Got it done and haven't seen him since.
You have to go in person because the parts guys sometimes aren't very bright so you have to kinda guide them through it, make sure its engine control module, i think its under emissions or powertrain section in their catalogue. Youll need to bring in your old one.
Old Mar 8, 2009 | 05:37 PM
McSteve's Avatar
I had the same issue and got a 01 Maxima one from car-parts.com for 130 bucks. Since it wouldn't idle and it is still cable controlled, i just put a little rubber ring behind the throttle body and that let me drive it to the dealership.
Old Mar 8, 2009 | 08:00 PM
oldngivout's Avatar
Willing to learn
2001 Max ECU may work in a 2001 I30 since the updated part number for each one is the same.
Seriously doubt if the 2000 Max will work, but the 2000 I30 might. Why not just get the correct one?
Old Mar 8, 2009 | 11:18 PM
Kaane's Avatar
Because I can't find any I30 2001 ecu's for sale. Only thing on carpart are maxima ecu's and they dont list if they are federal or california models. I dont want to get a federal maxima one and have issues.
Old Mar 8, 2009 | 11:21 PM
turbizzy's Avatar
I just told ya man, TRY AUTOZONE!
Old Mar 9, 2009 | 10:31 AM
oldngivout's Avatar
Willing to learn
All 2001 Maximas are CA emissions.
Car-part is an excellent resource for interchangeability of components. 2001 Max ECU will work in a 2001 Maxima also.
Old Mar 9, 2009 | 02:03 PM
Kaane's Avatar
ok great thanks a lot.
Old Mar 13, 2009 | 03:38 PM
talisman311's Avatar
Find a junk yard.. car-part.com
I snagged so many expensive things on my car on the cheap at the local junkyard.
Old Oct 12, 2009 | 05:43 PM
ericks_i30's Avatar
had to replace ecu in my 1996 i30 . place out of texas had a rebuilt with one yr warrenty 100$ 888-217-4072
the number came from websit talisman311 is referencing to.
soloist3
Sep 2, 2015 12:59 PM
95Maxi
35
Sep 2, 2015 10:37 AM
maxinout93
Aug 16, 2015 07:25 PM
doobadoo
Aug 15, 2015 06:43 PM
