directions for swapping steering wheels?
Old May 17, 2009 | 04:08 PM
97lude's Avatar
im about to swap out my normal steering wheel from my 98 i30 to a 98-99 limited wood i30 wheel. Is there a link for a DYI or anything?
greatly appreciated! (tried searching)
Old May 17, 2009 | 05:37 PM
BLACKonBLACK98's Avatar
Former Vendor
disconnect battery, remove airbag, remove nut, remove wheel (may need a puller, available for loan at most autoparts stores). installation is reverse of removal.
Old May 17, 2009 | 05:46 PM
whitealexander's Avatar
yep to this and your going to get there..
Old May 20, 2009 | 05:33 PM
97lude's Avatar
a little more desciptive directions would be much appreciated
Old May 24, 2009 | 04:06 PM
beeniesfoams's Avatar
Do you need to disengage the airbag, or does disconnecting the battery do that for you?
Old May 25, 2009 | 08:26 AM
Former Vendor
fsm will break it down for you if you have trouble identifiying and removing 5 nuts/bolts. you will also need a security torx socket iirc.
disconnecting the battery and letting it sit for a few minutes will prevent the airbag from going off.
trasmadean
Feb 1, 2017 08:20 PM
Maxima_Joe
Nov 25, 2015 08:19 AM
Maxima_Joe
Oct 15, 2015 08:01 PM
tnewbs
Aug 28, 2015 10:15 AM
Flores94
Aug 13, 2015 01:17 PM
