Sun roof and radio/temp light problem..
Old Dec 30, 2009 | 07:35 AM
AznTran517's Avatar
Ok well all of a sudden my sunroof just started to act funny.. When i try to open it, it only moves like 2 inch and stops.. I tried disconnecting my battery but that didnt work..
Now after that problem now at night time when I have my clock light, my radio and temperature lights dont come on.. wtf??
Old Dec 30, 2009 | 12:53 PM
The6spdMax's Avatar
Check fuses, or maybe some wires taping each other create a shortage. What did you work on your car last?
Old Dec 30, 2009 | 05:03 PM
AznTran517's Avatar
My foglight are not coming on also witch is pretty weird. I do have them wired to my tail lights but the tail lights work. I haven't worked on my car for a while.. I'll have to check the fuses in the morning.
EDIT: also when i try to dim the cluster light it will not dim..
Old Jan 2, 2010 | 09:06 AM
AznTran517's Avatar
So the reason I think my fogs are not coming on is because all the day time light are not lighting up. Do anyone know witch fuse I should check?
Old Jan 3, 2010 | 08:26 PM
AznTran517's Avatar
I checked the fuse under the dash and the fuse is still good.. Is there another fuse that I should check for?
Old Jan 3, 2010 | 09:12 PM
The6spdMax's Avatar
Why does your fog light wired to your tail light in the first place?? Doesn't make sense to me... I would undo every wire and set back to orginal. If that doesn't work. I would post this question in 5th gen section and someone might be able to help you out.
Old Jan 4, 2010 | 11:54 AM
AznTran517's Avatar
I did the foglight re wire to the tail light fuse under the hood.. I'm pretty sure it might just be a blown fuse somewhere but IDK where. This is pissing me off cause my tail lights dont come at night unless I use my brakes..
Old Jan 4, 2010 | 01:02 PM
The6spdMax's Avatar
Oh I see. I would recheck that fuse box. Where did you get the instruction from? There is a good link. http://www.shiftice.com/fog_rewire.html
fastcarny
Oct 6, 2015 10:42 AM
Maxie40
Sep 14, 2015 11:28 AM
Vequity
Sep 10, 2015 05:26 AM
-ReLLiK-
Sep 8, 2015 12:02 PM
Maxima30
Sep 7, 2015 06:13 PM
