ZOMFG!! They finally made a Metra Kit for the A33 I30/I35???
Old Sep 8, 2010 | 04:09 PM
  #161
BLaCKi30oNDuBS's Avatar
finally my wifes car can have a nice clean install
Old Sep 10, 2010 | 09:44 PM
  #162
ronan_zj's Avatar
Hey guys I think I need a little help from you, I am trying to replace the head unit of my I35 with Pioneer AVH-3200DVD, and I don;t know what wiring harness and radio adapter I should buy, I have check the amazon, and find these:
Antnna adapter and wiring harness .
Also this: http://www.sonicelectronix.com/item_...a+70-7551.html
could someone tell me what I should buy? or I have to buy all of these?
Old Sep 11, 2010 | 07:58 PM
  #163
Joeker82's Avatar
Your going to need the dash kit, the antenna adapter, and the metra 70-7551 if your going to run throught the stock bose amp and speakers. That is everything you need.
Old Sep 15, 2010 | 12:14 AM
  #164
ronan_zj's Avatar
Originally Posted by spreenyk888
i got the hu from crutchfield....i didnt get the 3200bt, i got the 3200 (same radio, just no bluetooth) for 399.99 shipped. it came with the wiring harness for the bose and the antenna adapter. i think you can also buy a part that will make your steering wheel controls work the new hu, but i dont have it.
Did you try to play AVI file on 3200DVD?
I tried to convert to AVI format, but the headunit could not play it.
Old Apr 7, 2011 | 01:55 PM
  #165
compton2k11's Avatar
this kit is only $16 off Amazon.com now
Old Apr 14, 2011 | 06:42 AM
  #166
mplomondon311's Avatar
I still love the one I got from Sycefiro with the wood trim. I called Metra a year ago and the guy had the worst attitude and said they weren't going to make one??? Bout time!
Old Apr 14, 2011 | 10:01 AM
  #167
Legendman's Avatar
anybody provide me with some tips on removing the center panel around the stereo.. Im afraid of breaking something..
Old Apr 14, 2011 | 10:27 AM
  #168
monched's Avatar
Wish I could help you out with that... but in my experience, once you've disconnected everything, it just takes a firm tug on the panel pieces and they'll come out. It's unlikely that anything will break.
Old Apr 14, 2011 | 10:44 AM
  #169
Legendman's Avatar
Wait a min, what exactly needs disconnecting from the trim.?? There are no visible connections??
I got the vents off! should be straight forward from here... Thxs!
Old Apr 15, 2011 | 10:32 AM
  #170
2001i30's Avatar
there is no trim around the radio, its part of the radio. you have to remove the center vents above the radio (I30s have the hazard button that needs to be disconnected) and remove the wood trim around the shifter. the radio and HVAC controls are held to the dash with 4 screws. Remove the screws and the entire radio and HVAC assembly is removed as one.
Old Apr 16, 2011 | 06:14 PM
  #171
Legendman's Avatar
Thanks!!!!!
Old Apr 17, 2011 | 05:31 PM
  #172
pahanorlando's Avatar
Looks nice. It makes me thinking about replacing dash stereo to get gps, ipod, and other functions. Is there any dash kit that has gps and ipod connector? may be with cd changer inside
Old Apr 22, 2011 | 11:29 AM
  #173
Sam o nela's Avatar
Lol I see you already got the tips here Legendman!
Yeah its pretty straightforward...just be patient and nothing should break.
Little warning though...just like with the A32s, the little phillips screws holding the headunit to the mounting bracket must have been tightened by Chuck Norris himself because they are impossible to get with a regular old screwdriver (so don't even try). Use a small impact wrench, a 90 degree screw driver setup, or just drill them out (I had to drill one out when I stripped it...doh!).
Old May 19, 2011 | 05:04 PM
  #174
bd0g36's Avatar
Looks good so far
I just bought the Metra kit on Amazon for 16.99 with free shipping with amazon prime. It came in yesterday and it looks good so far. The color seems to match well with the dash and the quality of the plastic is good enough. I just got my '01 I30 last week, and want to add the Pioneer Avic x930bt. I'll update as soon once I get it installed.
Old May 26, 2011 | 08:18 AM
  #175
bd0g36's Avatar
Just had the nav installed, here are the pics. It's not 100% perfect, but it's better than I thought it would be. Nice and clean, the color match is good, and the best part is having 2011 tech in my ride!
Old Jul 31, 2011 | 02:10 PM
  #176
oneduduboy's Avatar
Could someone please tell me what exact parts are needed to install a double din DVD player to replace a 2002 factory Bose cd player.. I've already ordered the metra dash kit, metra 751 harness, and metra antenna adapter.. Thanks in advance.. I'm a noob and this is my first post
Old Jul 31, 2011 | 02:23 PM
  #177
Pac Roemnis2 is what you need instead of 7551 if u want to keep factory speakers
Old Jul 31, 2011 | 02:32 PM
  #178
Thats all you need
Old Aug 1, 2011 | 12:03 AM
  #179
oneduduboy's Avatar
what is a Pac Roemnis2 if you don't mind me asking. I already ordered the metra 70-7551 1996-2005 Infiniti Amp integration harness. Should I cancel the order for the metra harness?? TIA
Old Aug 1, 2011 | 04:44 AM
  #180
Yeah. Cancel. I'll tell u little later
Old Aug 1, 2011 | 11:44 AM
  #181
When you connect 7551, your sound will be VERY quiet because you connect it to RCA. I am not exactly sure why, but you can read about it in audio electronics section on this forum. What Pac Roemnis2 does is converting the sound to appropriate level so it will sound exactly right. Its pretty easy to install, nearly the same way as 7551.
Also, you might want to buy steering wheel control module, that's what I replaced too
http://bestpcreviews.com/car/206-pac...ce-review.html
Old Aug 1, 2011 | 05:48 PM
  #182
oneduduboy's Avatar
Thanks for all the great advices.. I'll try to cancel my 7551 ASAP..asking you please advise me where is the best place to order the pac roemnis2 at?? Thanks so much
Old Aug 1, 2011 | 09:54 PM
  #183
I ordered mine on amazon and it was $10-$20 cheaper than retail price. You can also check ebay, but amazon is more reliable IMO
Old Aug 15, 2011 | 01:43 PM
  #184
jglaw's Avatar
Link to the amazon kit:
metra kit on amazon
Old Aug 18, 2011 | 02:16 AM
  #185
ozeinab87's Avatar
Need help!
Hello everyone, as I went through this thread, i came across a lot of things that got me little confused. I recently bought an American Imported i35 2002 model in the Middle East, and I really love this car so far
It is very clean, it has only done 51,000 miles! anyhow, what I need is if someone can summarize me a list of the things i need to buy/do for me to fix an after market radio, and i would really appreciate it if you send me links as well.
here what i need, and i hope you guys will help me out:
1st of all, is there anyway to the fix the radio frequencies so that it can read channels like 104.4 not only 104.5/3
2nd, am planning withing a month to install an aftermarket indash double din gps system, and i need to maintain my bose speakers and steering wheel controls. So please if you can provide me with a list of the things I need to get to make my life easier, because since i am in the middle east, i need to get most of these things, like the metra kit, online
OZ
Old Aug 18, 2011 | 08:01 AM
  #186
1st question, you can't do it on stock HU, but probably some aftermarket HUs are capable of switching radio frequencies light that
2st question,
Pac Roemnis2
99-7609G Metra Dash kit
40-NI10 Metra Antenna Adapter
For steering wheel controls it depends on what aftermarket HU you gonna use
Old Aug 18, 2011 | 04:27 PM
  #187
ozeinab87's Avatar
2st question,
Pac Roemnis2
Thanks a lot pahanorlando, fastest reply i have ever gotten
Can you please explain me what r these for exactly? and regarding the aftermarket HU, any recommendations?
Old Aug 18, 2011 | 04:50 PM
  #188
Joeker82's Avatar
I can help Big O out on this one. I bet he's eating lunch or something...
Pac Roemnis2 - This is so you can run your Bose speakers/ amp with a aftermarket deck. The nice thing about this unit is you can control your output gains to tune your volume level.
99-7609G Metra Dash kit - This one explains itself. This is your dash install kit.
40-NI10 Metra Antenna Adapter - Another one that speaks for itself. Factory Nissan antenna plugs are round with two male connectors. Your aftermarket deck will be one male connecter. This adapter allows two into one.
Old Aug 18, 2011 | 06:52 PM
  #189
Lol thanks Joeker. I am actually delivering pizzas right now
Old Aug 20, 2011 | 07:20 AM
  #190
ozeinab87's Avatar
Thanks for the info mate, highly appreciated!
Old Dec 3, 2011 | 09:55 PM
  #191
ozeinab87's Avatar
Trip and Audio Steering Wheel Control
hey guys, I have recently bought and fixed a chinese android/windows double din stereo. Altough it supports steering wheel audio control, it needs a kit, otherwise, i have to cut the oem cables and play with them, which i dont intend to do to be honest! so if anyone can tell me what kit/converter do i have to buy to get it working?
Another thing is the Trip button, it is no longer working, so what do i have to do to get it back?
Highly Appreciated!
Old Jan 6, 2012 | 11:59 AM
  #192
jglaw's Avatar
Audio Quality
How is the audio quality with the ROEM-NIS2? It looks like it does not use RCA at all for audio to the Bose amps which would not deliver the same audio quality as the RCA connection although it may be louder.
Would this device do the same thing and retain RCA connections?
http://www.pac-audio.com/productDeta...&CategoryID=28
Old Jan 6, 2012 | 04:01 PM
  #193
Joeker82's Avatar
You could always put it on the outs of the factory amp. It's in the trunk on the passenger side. Under the rear deck. Best thing to do is, gut it and get new speakers, and bypass the bloze amp!
Old Jan 8, 2012 | 12:20 PM
  #194
pat6290's Avatar
What's better for the bose adaption: The Pac ROEMNIS2 or the Metra 70-7551?
I've seen mixed reviews everywhere. I have an '02 i35
Old Jan 10, 2012 | 10:51 AM
  #195
AznRyan's Avatar
This is awesome. Now I can replace my HU to go along with the new amp/sub under the rear deck
Old Mar 21, 2012 | 04:44 AM
  #196
laststop's Avatar
What if you want to keep the factory amp, but use a new head unit and speakers?
Old Mar 21, 2012 | 12:12 PM
  #197
MaxMike93's Avatar
Is that the AVIC-x930BT? I was thinking about getting the new one (x940BT) for my I30 this year. I have the Metra kit with my Clarion NZ500, but me and my dad (he used to do professional car electronics) kinda hate that kit. Just because of the crap fit, and that it isn't a perfect color match. Then I got the Sycefiro kit (I think he has one left) and I can't wait to put that in with a new 2-din head unit
Old Apr 19, 2012 | 11:52 AM
  #198
laststop's Avatar
Got my Metra kit and it is much darker than factory on my 01 i30 with beige interior. Darker than the one bdog posted. Do they make these in different colors and is it even work it to try and paint it?
Old Apr 25, 2012 | 03:50 PM
  #199
laststop's Avatar
Here's the color mismatch I was talking about earlier. It's worse with the vent area than the stock unit trim.
Old May 19, 2012 | 07:46 AM
  #200
mitrals's Avatar
I have the Metra 70-7551 and the sound quality is very disappointing. I checked the wires and everything looks ok, but the sub doesnt work. I am going to try the PAC adapter and see how that goes!
