Coolant level drops within days. . . .
Old Jul 27, 2010 | 04:38 AM
Chester86's Avatar
Hi folks,
I just replaced my radiator after I noticed a leak from the crack. I thought this was a simple procedure, but . .guess not. Now, I start to notice that the resovoir drops in coolant level within a few days. I check frequently after a good drive to see if there are any leaks within the hoses, clamps, or any area. Still no luck and the coolant level continues to drop. Does anyone have any suggestions? I read another post stating it might be the water pump? Is there any way to check the functionality of the water pump? thanks folks!
Old Jul 27, 2010 | 07:29 AM
phatboislim's Avatar
weak head gasket? have you checked your oil? do you smell any coolant while driving or when you are under the car? locate the water pump and see if its wet around it
Old Jul 27, 2010 | 05:38 PM
Chester86's Avatar
I do smell coolant after driving and it does smell while I drive. But, after a drive I never see any visible leaks under the car or around the engine bay. If a water pump doesn't work any more is it likely to cause a leak or evaporation of the coolant?
Old Jul 28, 2010 | 05:22 PM
Col Ronson's Avatar
i seriously doubt its a head gasket. Those problems are almost nonexistent on a VQ. My coolant level dropped drastically one day, but i was overheating cuz the fans had failed. It also could be your water pump is leaking?
Old Jul 28, 2010 | 08:23 PM
soto2635's Avatar
water pump???
Old Jul 28, 2010 | 09:36 PM
Look and see if you're leakng any coolant from the passenger side near the front wheel. The water pump is around there.
Miket2006
Mar 1, 2021 03:55 AM
mclasser
22
Nov 12, 2020 01:58 PM
maxima-junky
Oct 7, 2015 06:13 PM
