O2 Sensor, Direct Fit-Color Coded or Not?
Old Dec 7, 2010 | 11:14 PM
osetleo's Avatar
I got the Denso sensor today from Amazon, Denso Part No 234-4270. It says it is direct fit, however, it is black color instead of white. I thought they will be color coded as the OEM sensors. It should be replacing the OEM sensor 226A0-5Y701.
Did I order the wrong one?
Do you folks know if color code follows with sensors from Denso, NGK, Bosch?
Old Dec 15, 2010 | 10:26 PM
jglaw's Avatar
If it's OEM it should fit, different manufacturers probably just use different colors.
Not sure if there's a difference between the upper and lower O2 sensors but you may want to check that as well.
mvm062
Nov 30, 2020 09:00 AM
ballerchris510
Sep 23, 2015 08:46 PM
DarjeelingRose
Sep 15, 2015 01:20 AM
