as most of you know when you hold the unlock button on your keyfob for more than 3 seconds your windows roll down (if you didnt know, youre welcome
) and the only way to roll them up outside the car is by inserting the key in the door and holding toward the lock direction for a few sec's.....
my question is: can you add a relay/auxiliary device to roll UP the windows from the keyfob? Anyone done it? or even thought of it?
NGK
) and the only way to roll them up outside the car is by inserting the key in the door and holding toward the lock direction for a few sec's.....my question is: can you add a relay/auxiliary device to roll UP the windows from the keyfob? Anyone done it? or even thought of it?
NGK
Im pretty sure it will, try it. Also, found a link from another forum from one from KP -
http://www.kptechnologies.com/products.php#/17
NGK
NGK
yea probably why. It works with the factory keyfob (remote) however, if you bought a good aftermarket remote start/alarm like DEI then you should be able to add an auxiliary up/down feature pretty easily
On my '02 I35 when I try this it starts to roll up but then stops. It acts as if something is blocking the window (like the fail-safe for the auto-up feature).
Any ideas why this may be happening? Nothing is blocking its path when I try this.
My girlfriends car is 2000 maxima SE and hers rolls down and up with the key. I have a 2008 and mine rolls up and down with the keyfob and using the key in the door
Our Lexus is the same. You can roll the windows down with the remote, but to roll up, either turn the car on or put the key in the lock and turn it towards the lock direction...
