problem with Progress rear sway bar width
Old Dec 2, 2011 | 02:43 PM
Mad_A's Avatar
I am trying to install a progress rsb that I bought from a 5th gen maxima owner. when I came to bolt up the last side, I found it was an inch short. So I had the two rear bushings bolted using the u bolts to the axle, and one side bolted to the rear trail arm, and the other side was an inch short.
I took it off and took some measurements: RSB width from end to end-> 43 inches. Distance between rear trail arms -> 44 inches.
Are the rsb's not compatible from teh 5th gen to the I35? In my case it is a 2002 I35.
Old Dec 2, 2011 | 02:52 PM
Mr. Brett's Avatar
Hey. I'm at work right now. I've got internet access, but can't use my phone. I'll give you a shout as soon as I can. But as far as I know, the RSB will fit both the I35 and the Maxima. The specs on the rear trailing arms are the same. Let me look for a minute and see if I can find the install how-to for you.
Old Dec 2, 2011 | 02:54 PM
Mr. Brett's Avatar
http://forums.nicoclub.com/4th-5th-g...b-t157914.html
Give that a shot. If it doesn't help, let me know, and I'll give you a call and see how I can help.
Old Dec 2, 2011 | 04:53 PM
JNCoRacer's Avatar
Just the tip.
That was the directions I used when I installed my Addco yesterday. I kinda ran into the same problems, but then I realized I needed to just loosely put everything on and then tighten it down.
Old Dec 2, 2011 | 07:02 PM
Mad_A's Avatar
Thanks Brett. That is the guide I used, I had everything on there pretty loose. The measurements are what worry me, there is no way to make up a full inch. My plan is to get a machine shop to fashion 4 quarter-inch spacers the same shape as the side bracket base plates, and use two on each side, along with longer bolts.
Old Dec 2, 2011 | 07:04 PM
Mad_A's Avatar
Yo! I am totally gonna have you come over and take a look at this with me
I am out of town from tomorrow till Friday for work, then I'll give it another shot when I get back.
Old Dec 2, 2011 | 07:35 PM
JNCoRacer's Avatar
Just the tip.
Yeah just let me know. You got my number.
Old Dec 19, 2011 | 05:37 PM
Mad_A's Avatar
So I got the rear sway bar on. I used two jack stands to hold it up in position and locate it exactly in between both rear trail arms and JNCoRacer came over, took a look and said that it should bolt up fine as his had about the same space on each side. And sure enough... I must have just had it too tight on one side the first time I tried.
Old Dec 20, 2011 | 07:32 PM
sascuderi's Avatar
How does it handle now after the install??
Old Dec 21, 2011 | 08:14 AM
Mad_A's Avatar
Very noticeable improvement! My suspension is otherwise pretty much stock, so I could notice the big reduction in body roll right away. Now, if you already have stiffer springs and shocks, it probably won't be as huge of an improvement as it was for me.
Old Dec 21, 2011 | 08:36 PM
Rods03Max619's Avatar
NICE, you got it on I was going to say just sell it to me, since I lost mine with my other Max totaled....
ef9
Aug 27, 2015 07:21 AM
seesole
Aug 26, 2015 11:22 AM
Dasmith
Aug 25, 2015 10:15 PM
Maxboy23
Aug 20, 2015 09:33 AM
MaxStock
Aug 14, 2015 10:03 PM
