2000 I30 Stock Exhaust Diameter?
Jan 18, 2012 | 07:01 PM
One of my exhaust hangers broke and it keep making a s**tload of noise when I go over bumps. All that happened was that the weld broke holding the hanger onto the pipe. So my friend took it and says we can put a clamp onto the hanger to secure it to the pipe. But I don't know what diameter the pipe is. The hanger is the one right in front of the gas tank. I know the proper way to do it is to weld it back, but with corrosion on the hanger edge, and that I'm a pretty broke college student, this seems to be a good fix for the moment. Thanks!
Jan 18, 2012 | 07:21 PM
Here you go man:
http://forums.maxima.org/5th-generat...pipe-size.html
5th Gen = Your I30
So 2-2.25 inch. But If your talking about the exhaust "in general" I have a hunch it's 2.25
Jan 18, 2012 | 07:47 PM
5th Gen = Your I30
Thanks for the info. My friend sent me a pic of how it looks. On the right is the stock mount, which gets welded to the exhaust pipe. The left is the new bracket he made that goes around the pipe
Jan 18, 2012 | 07:54 PM
Quote: Thanks for the info. My friend sent me a pic of how it looks. On the right is the stock mount, which gets welded to the exhaust pipe. The left is the new bracket he made that goes around the pipe
Must have a rusty exhaust for that mount to fall off haha. Pretty nifty to make that bracket, give an update on how it goes! What do you need the dimensions for though, the bracket?
Jan 18, 2012 | 08:09 PM
Quote: Must have a rusty exhaust for that mount to fall off haha. Pretty nifty to make that bracket, give an update on how it goes! What do you need the dimensions for though, the bracket?
Yea. That ring goes around the pipe so I need to know how big the pipe is to fit the ring around
Jan 19, 2012 | 02:19 PM
Ghetto fabulous!
Jan 21, 2012 | 11:39 AM
Well, seems like that mount works perfectly. No rattle anymore every time I go over a hump in the road. And just by the way Joeker82, my friends and I prefer to use the term 'rednecked'
Mar 14, 2012 | 10:06 AM
Next failure will be the puny 8-32 screw going thru the isolator! You should've used a larger bolt!
Mar 14, 2012 | 10:53 AM
Quote: Next failure will be the puny 8-32 screw going thru the isolator! You should've used a larger bolt!
Not my exhaust
Mar 14, 2012 | 03:53 PM
Nothing bad has really happened. No more banging since that now the pipe is being held firmly in place. And it's been on the car for months now
