car will not start !!!
Old Nov 14, 2012 | 06:27 PM
3randon's Avatar
My 2000 infiniti i30t will not start. I have replaced both the positive and negative battery clamps, installed an optima yellow top battery and all i get when i turn the key is a click. It sounds like it is trying to put power to the starter because it makes an electrical noise and also from under the hood i hear something like pressure releasing. I need this car running. Any suggestions would be appreciated. I also replaced both the positive and negative clamps that attach to the batyrty
Old Nov 14, 2012 | 06:30 PM
2brosgixxer's Avatar
Try having someone TAP on the starter with a hammer when you turn the key to start it. Sounds like what my starter did when it **** the bed.
Old Nov 15, 2012 | 02:34 AM
wasdpp's Avatar
Are you using a spare key? If so, that might be the chip is dead if not then its probably your starter is shot. I had the same thing.
Old Nov 15, 2012 | 09:11 AM
DennisMik's Avatar
That key suggestion is way off track in this situation. I'm betting that a replacement starter gets the car running.
Lakersallday24
Jun 16, 2019 01:35 AM
kjlouis
Nov 24, 2018 06:09 AM
MAXSE5SPD
Aug 23, 2015 12:06 PM
MaximaDrvr
Aug 19, 2015 08:20 PM
Balkins
Aug 12, 2015 06:39 AM
