Getting it running
#45
Did you go though the set up on the VAFCII? There is a setting that needs to be changed depending on what MAF you are running. If you look at the owners manual for the VAFCII it tells you what that setting is.
Where is the fuel line going that comes off of the fuel filter?
Have you checked the compression yet?
Will it run momentarily if you squirt a little starting fluid in the tb/intake (please don't blow your self up)?
When you wired the Z32 MAF did you change any wiring as compared to the A32 MAF?
If your CEL on? Have you scanned to see if you have stored codes?
Can you post pictures or videos of anything you are talking about?
#49
Also, no didn't run a compression test, I'm starting to aim to cam & crank sensors or maybe something went wrong with this car before I bought it? It's a nice car but I don't think the previous valued it & screwed it up!
JoshG
51
09-21-2015 10:41 PM
RWCreative
09-21-2015 11:01 AM
ballerchris510
09-10-2015 09:35 PM
