Can I make a 02 I35 starter fit my 00 infiniti I30
Old Jan 3, 2015 | 10:42 AM
maxmadman84's Avatar
Can I make a 02 infiniti I35 starter fit my 00 infiniti I30 thanks I already did a front and rear conversion and I have the 02 as a parts car any input will be greatly appreciated
Old Jan 3, 2015 | 10:56 AM
Fakie J Farkerton's Avatar
No.
Old Jan 3, 2015 | 03:07 PM
My hunch would be no. But I'd have to see pics to be sure.
Old Jan 3, 2015 | 10:33 PM
DennisMik's Avatar
The 2 cars use the same starter, part number 23300-2Y900.
For the 2002, there is a 2nd starter used. For years, the starters were made by Hitachi but Infiniti also started using a starter by Mitsubishi as well. It may look a little different but it is interchangable. The Mitsubishi starter part number is 23300-5Y710.
Old Jan 3, 2015 | 11:31 PM
The 2 cars use the same starter, part number 23300-2Y900. For the 2002, there is a 2nd starter used. For years, the starters were made by Hitachi but Infiniti also started using a starter by Mitsubishi as well. It may look a little different but it is interchangable. The Mitsubishi starter part number is 23300-5Y710.
If this is true it must be automatic specific.
Old Jan 4, 2015 | 11:58 AM
DennisMik's Avatar
The Hitachi starter part # 23300-2Y900 is listed for both the auto and stick transmissions.
But there is a different Mitsubishi starter for the 2 transmissions.
Part number 23300-5Y710 is listed for auto trans.
Part number 23300-5Y715 is listed for standard trans.
I have no idea what the difference would be.
Old Jan 4, 2015 | 12:02 PM
DennisMik's Avatar
Since I have never done this swap/interchange, I cannot argue that I am right. If someone feels strongly that my information is wrong, then I will not contest it.
Old Jan 4, 2015 | 12:03 PM
Guess what I'm going off of is that when going from auto to manual for a 6 speed swap, I know you have to use a manual starter.
Something about the way the flywheel is spaced.
A32goldylocks
Sep 2, 2015 06:39 AM
evonder73
Sep 1, 2015 02:21 PM
umnitza
Sep 1, 2015 01:03 PM
kirkhilles
Aug 8, 2015 10:53 AM
