Best I35 replacement Starter
Old Apr 20, 2018 | 07:23 PM
osetleo's Avatar
Folks, would you please suggest the reliable starter for replacement on I35. I don't want to buy a dealer starter but would like to consider reputable OEM replacement. I have an occasional cranking issue. I have replaced the ignition switch and relay, but after 2 months once in a while the car clicks and does not start. It happens every other 5 starts, so I am thinking it is a starter.
Would appreciate your input. Thank you
Old Apr 21, 2018 | 09:09 AM
DennisMik's Avatar
Replacement starter are a crap shoot. There is no guaranteed to be good starter (or alternator) out there. You have the re-built starters and the brand new starters to choose from. Neither one is better than the other.
The starters and alternators from the dealer are rebuilt units, the letter R on the end of the part number indicates that. When it comes to rebuilt units, it all depends on the company that did the rebuilding. A few are good, most are not. What you get from your local auto parts store will be the same as anywhere else. Most will work out of the box, some won't. Some will still be working a year later, some won't.
The new manufactured starters are pretty much like the rebuilt ones. They are made in China and are cheap garbage.
It is depressing. Just get a good guarantee and hope it works. I would suggest that you buy it at a local store rather than order it on line. The reason being is that if it fails, you can go to the store for the replacement instead of waiting several days for shipping.
Old Apr 22, 2018 | 03:24 PM
osetleo's Avatar
That is what I was planning to do, so I called Autozone this morning. All manufacturers that I never heard about, no Bosch, or Mitsubishi, or AC Delco-old reputable names for electrical after market components. It is really scary what to buy???
Old Apr 22, 2018 | 03:26 PM
osetleo's Avatar
Thank you, Dennis for sharing your frustration
Old Apr 22, 2018 | 11:33 PM
AaronL's Avatar
Your best bet is to find a local alternator/starter shop that does rebuilds and have them rebuild your starter. Of course this depends on that shop doing a quality rebuild, so check reviews if you can.
leeI35
May 27, 2019 10:04 AM
maxmadman84
Jan 4, 2015 12:03 PM
atriuum
Oct 4, 2010 09:56 PM
Daily Interlude
Dec 21, 2006 10:36 PM
skuccio's max
Apr 22, 2003 03:42 PM
