Bringing a 2001 i30 back to life
Old Feb 28, 2022 | 08:22 AM
blkmax1's Avatar
Just picked this up and I want to bring it back to life. Slip and Tcs lights are on, what can be the issue with that? Also needs a good tune up
Old Feb 28, 2022 | 08:25 AM
blkmax1's Avatar
First I will change plugs and coils due to the missing and then start going thru entire car
Old Feb 28, 2022 | 10:46 PM
blkmax1's Avatar
Cats are clogged. What options I have for best results and Od light flash upon start up
Old Mar 1, 2022 | 05:19 PM
Reality sucks's Avatar
The OD Flash can Mean a Few things. Scan the trans for Codes. I would also Check Charge Voltage. Make sure the alt and battery are in good health aswell.
I would buy cats and put them back on the car. The 3.5 will just shut down with a glogged cat. I have no recommendation other than to Not gut them. Its not a bad job to do. What is most important though is that the engine is in good running condition first.
Old Mar 2, 2022 | 01:19 PM
blkmax1's Avatar
Ok great I’ll start doing things and go through the car. First I’ll start with plugs, cats, and tune up
Old Mar 6, 2022 | 02:12 PM
blkmax1's Avatar
What are some things I should do to ensure reliability for a while. What about that idle air control valve mod so it doesn’t burn out something in the ecu?
Old Apr 13, 2022 | 05:38 AM
blkmax1's Avatar
So the cats weren’t clogged and I did a tune up but the car still misses at times. Yesterday the car kept bogging down and wouldn’t move. The car has no power down low and when I try WOT it won’t even redline etc
Old Apr 13, 2022 | 05:46 AM
blkmax1's Avatar
Can it be my mass air flow sensor ? Sometimes it idles smooth then other times it misses and sputters
Old Apr 13, 2022 | 05:56 AM
blkmax1's Avatar
The od light flashes upon start up can it be a trans issue
Old Apr 18, 2023 | 12:48 PM
wezmykat's Avatar
the lights being on could be many different things, could be as simple as a bad speed sensor could be the ABS module fried, you need to diagnose it (use a haynes manual) or bring it to a good mechanic
the low power issue could also be different things, what comes to mind right away is a bad/weak fuel pump or clogged/dirty fuel filter or fuel lines, could be a dirty/clogged air filter, some really basic stuff you need to check
did you take apart the throttle body and clean it ?
95maxrider
Nov 24, 2019 07:32 AM
TonyJr
59
Apr 28, 2016 06:53 PM
zgrm100
24
Aug 19, 2014 03:51 PM
Prophecy1
May 11, 2005 01:53 PM
jordanius83
Feb 5, 2004 07:10 AM
