Evo e-brake handle on 6th Gen Maxima
Old Feb 5, 2006 | 09:28 PM
DeusExMaxima's Avatar
I went to Mitsu dealer to check out the Momo e brake handle for an 06 Evo MR to match my Evo MR shift ****. I got the same run around when I called dealers since this part is an accessory even though they come on the Evos when they come into port here in USA. The part number is hard to find and NO ONE stocks it. I just happen to know that Glendale Mitsu had one, so I made my way down to Glendale. Oh, and on the way, I picked up some Altima SE-R aluminum pedals from Performance Nissan in Duarte, CA. Thats where I spoted the Max with Nismo rims (check out my thread on that topic.) They only charged me $114 for the pedals!!
TWhen I got to Glendale Mitsu, he took the beautiful e brake handle out of the box and notices a slight scratch on the handle. He told me he would discount it cuz of the scratch. He said the regular price was $172, although they told me $220 when I was there before. When he rang me up, he charged me only $85!!!!!!! Yeehaa!!! U can barely notice it.
When I got my prizes home I put on two of the pedals. Ill do the others later. The e brake handle was tougher. Removing the fugly runner shzit cover of the stock brake was tough. I ended up jamming a screwdriver between the shaft and the rubber(!!) cover and finally after cutting my figner and spraining my wrist, got the motha off. The Evo handle has a nub inside that had to be sanded off which was very easy since its aluminum. Then is slides right on. I need to get a leather boot for it but here are pics. In one pic, the aluminum pedals are seen. Let me know what you think! Gd I love my car.
Before:
After:
Old Feb 5, 2006 | 09:31 PM
Glude's Avatar
Almost looks like fake carbon fiber, is it real?
Old Feb 5, 2006 | 09:32 PM
Very real!!
Old Feb 5, 2006 | 09:42 PM
jsmithsole's Avatar
*moderator*
Deus you should have bought a vacumm while you were out!!! lol
Looks sweet, I was thinking to get the SE-R pedals as well, let me know how easy they are to install...
Old Feb 5, 2006 | 09:48 PM
Glude's Avatar
Man ive been putting off installing my autovation pedals because I dont wanna drill them on crooked...lol.
Old Feb 5, 2006 | 09:49 PM
I was gonan get a shop vac today but was too busy, J!! LOL. The clutch and brake pedals were a bit of a bzitch. I havent doen other two yet. The dead pedal is gonna require some work. The regular Alti has plastic dead pedal that snaps in place. Since we dont have that, I am going to grind off the nubs on the plastic underside, and then screw it in with black drywall screws. The accelerator pedla should be a swap. Ill keep u posted.
Old Feb 5, 2006 | 10:02 PM
jsmithsole's Avatar
*moderator*
Might have to make a trip out to Upland and have you help me out!! Like Glude said mine would probably end up crooked!!
I saw a couple different MOMO ones that I was thinking about getting:
Old Feb 5, 2006 | 10:05 PM
SoCalMax05's Avatar
J - Since Deus dons't read e-mail - let me know when your coming up - we will hook up.
Old Feb 5, 2006 | 10:06 PM
SoCalMax05's Avatar
WOW - I can't type for S&%$
Old Feb 5, 2006 | 10:21 PM
I dont read email?
I thought about aftermarket pedals, but the stock ones basically bolt in, and they look sharp.
Old Feb 6, 2006 | 07:51 AM
myer84's Avatar
I bought an e-brake while back and never installed cause cant figure out how to remove the stock one. Any tips or instructions out there?
Old Feb 6, 2006 | 08:28 AM
Majestic_MAx05's Avatar
Looking nice deus!!!
Old Feb 6, 2006 | 09:15 AM
04BlackMaxx's Avatar
I cant wait to see the next gen evo, unfortunately its going to be in mid 2007...but good I guess bc the max will be almost paid off. Mitsubishi offers a 5yr 60k bumper to bumper and a 10y 100k powertrain...I couldnt believe that, thats definately the clincher for me after dealing with warrenties!
Old Feb 6, 2006 | 04:38 PM
Myer84: Here is how I removed the fugly rubber parking brake boot. First you pull the metal ring out of the nose of the handle, right where the button is. I then removed the trim at the base of the parking brake (plastic aluminum). This opens the bottom of it and you have access to the entire boot. I heard using a blow dryer softens the rubber to where u can remove it. I tried it and it may have helped, but not much. What worked was jamming a screwdriver through the nose of the handle, right where the metal ring was. U try to separate the rubber from the metal shaft. if u dont care about the boot u can always cut it off. it took some work but it popped off. Actually it was so much work, I ended up spraining my wrist, grrrr. But that was before I used the screwdriver on it. Its a worthwhile mod!!!
Old Feb 6, 2006 | 04:47 PM
LA02MAX's Avatar
wow, i think that looks really nice...were you also in the middle of installing the AE (or w/e ya'll 6th genners call them) pedals? In the first picture, you can see that the clutch pedal is missing, but in the last one it's there and the accelerator pedal is missing
Old Feb 6, 2006 | 05:53 PM
maximob's Avatar
Yeah,,,sprain your wrist, cut your finger and jam a screwdriver into it..
Old Feb 6, 2006 | 06:32 PM
BD231's Avatar
You don't serve Hamburger's with rice!
Get your max some damn French Fries (wood grain trim), It's 30k car that weighs over 4 thousand pounds man!
I don't like it, but through my eye, hand brake's are actually pretty ugly no matter how you dress'em up. Wish the pedal with leaver release was still around.
Vacuum's a good idea too, been choppin wood lately??
Old Feb 6, 2006 | 10:32 PM
Actually the Max weighs in a LOT less than 4,000 lbs, unless everyones data is wrong. My shop vac broke and I have been looknig for one, but I wanted to get these pics up, so I had to forego the vacuum til I buy a new one. Not only do I love the new look of the pedals, e-brake handle, and shift ****, but I love the solid feel too.
Old Feb 6, 2006 | 10:34 PM
LA02: In the first pic, I hadnt done anything yet. In the second pic, I installed the e-brake handle and 3 of the 4 aluminum pedals. I hadnt the time to do the accelerator cuz its more involved.
Old Feb 7, 2006 | 04:54 AM
I think the OEM brake lever looks great, its modern looking IMO.
Old Feb 7, 2006 | 09:54 AM
Old Feb 7, 2006 | 10:03 AM
chernmax's Avatar
Nations 1st 6th Gen Turbo
I have the bottom momo set in Red for an auto...
Old Feb 7, 2006 | 10:05 AM
Love that red, Chern!!!
Old Feb 7, 2006 | 11:35 AM
chernmax's Avatar
Before:
After:
Dues, did you have to cut your Ebrake rubber off in order to install the EVO handle? I did because my Ebrake handle (TENZO-R) is billet aluminum and encloses the whole upper handle shaft.
Old Feb 7, 2006 | 12:08 PM
2K3MAX2NV's Avatar
"tse-tse fly"
Looks AWESOME!! Great job! I just called mitsu in NY they want $248.77 what a joke! Do you have the part #?
Old Feb 7, 2006 | 01:04 PM
ajcool2's Avatar
Looking good man. I like it.
Old Feb 7, 2006 | 10:14 PM
Chern: I pulled it off, didnt have to cut it, but cutting would have been waaay easier.
2K3max: I dont have part # on me but ill get it to u soon. Its only $172 for the brake handle.
Old Feb 8, 2006 | 10:38 AM
2K3MAX2NV's Avatar
"tse-tse fly"
maybe the dealership in CA is better than the one in NY cuz thats the price he gave me...I wonder if they would ship it to me?
Old Feb 10, 2006 | 06:36 PM
tc5953's Avatar
nice handle looks clean like they should have done it that way stock!!! good job
Old Feb 11, 2006 | 04:42 AM
amimaxima
the e brake handle looks ok but the shift **** is ugly
Old Feb 14, 2006 | 11:18 AM
JamesBahn's Avatar
looks good. I love the momo pedals too
Old Feb 16, 2006 | 12:09 PM
ramberg's Avatar
GrandPa
Very real!!
For the price it better be real.
Lakersallday24
Nov 7, 2024 07:31 PM
CRizz
41
Jun 7, 2021 05:42 AM
morteljc
Oct 19, 2015 10:47 AM
dutch078
Wheels/Tires
Aug 3, 2015 06:58 PM
