Mazda FD3-S 16x8's on 4th gen.
Old Mar 27, 2007 | 03:42 PM
Fr33way™'s Avatar
Wild for Width
My '98 with '93 Mazda RX7 13.8lb 16x8's. I know Ludacris had these years ago but thought I would share. 5mm spacers not installed in picture.
Old Mar 27, 2007 | 03:44 PM
AE-Max's Avatar
looks good.
got any side shots?
Old Mar 27, 2007 | 03:45 PM
nismology's Avatar
Wide and light. Nice upgrade.
Old Mar 27, 2007 | 03:57 PM
Fr33way™'s Avatar
Wild for Width
For the money, can't do better IMO. "A wheel after my own heart." (To quote Nealoc187)
I will try to get you guys some better shots, just wanted to get it up for a few curious members. If you search for Ludacris' Maxima he has some very nice shots.
Old Mar 27, 2007 | 04:22 PM
Tatanko's Avatar
Bacon Lover
Love those wheels. Would love to have a set myself!
Old Mar 27, 2007 | 04:27 PM
LA02MAX's Avatar
I wish those could fit over my brakes
Old Mar 27, 2007 | 04:38 PM
Fr33way™'s Avatar
Wild for Width
You would need a fist sized spacer with this offset (50mm) LOLz.
Old Mar 27, 2007 | 06:20 PM
LA02MAX's Avatar
Originally Posted by Fr33way™
You would need a fist sized spacer with this offset (40mm) LOLz.
Offset isn't the problem. My wheels are 45mm offset. It's the diameter. My brakes are just about touching my 17s...
Old Mar 27, 2007 | 06:54 PM
|Bijan|'s Avatar
UCF Lexus
oh thats why you wanted to go to the track.....
nice dude
Old Mar 27, 2007 | 07:04 PM
Fr33way™'s Avatar
Wild for Width
Baby steps in the Kosei K1, SSR Comp C, Volk TE-37 direction.
Old Mar 27, 2007 | 09:42 PM
99grnmaxgxe's Avatar
Nice, they look great. lol I thought you were banned but I guess you changed your title.
Old Mar 28, 2007 | 12:44 AM
MorpheusZero's Avatar
Dayumn. Nice to see another non-kitted 4th gen with wide, light OEM 16s and a drop.
Looking great man. Wish you lived closer, haha.
Note to self, must weigh Z32s...
Old Mar 28, 2007 | 09:05 AM
Fr33way™'s Avatar
Wild for Width
I have to admit when I saw that you went TT's on all four corners I started checking around, just happened to get to these first.
Old Mar 28, 2007 | 12:44 PM
Cliff Clavin's Avatar
Way out West
Look nice, excellent weight on those.
I really miss my 14 lb 17-inch Centerlines
Everything else seems like boat anchors.
Old Mar 28, 2007 | 01:31 PM
RA030726's Avatar
I'm nutty for Nissans
The rears clear the dust cap w/o a spacer?
Tires and size?!
Whatja pay?!
I take it these are the hollow spokes, watch out for cracks as they are fragile. A Max is heavier than the 7 so its possible they *could* break.
Whats on the grille for an emblem?
Old Mar 28, 2007 | 02:39 PM
Are you going to run without centercaps? These are what I wanted to get originally but a set was really hard to come by, especially for cheap. I found the Z32TTs first. How about a few pics with the wheels straight to see how they flush up?
Old Mar 28, 2007 | 03:33 PM
Fr33way™'s Avatar
Wild for Width
Tires and size?!
Whatja pay?!
The dust cap isn't the issue, when the lugs are "tight" (or rather at the end of the lug) the wheel is tight but the rotor floats about 3-5mm. I knew I needed spacers in the rear but when I mocked up the rears for clearance everything was fine, it wasn't until I took a 35ft drive that I heard some chirping (rotor float).
The tires are Toyo Proxies FZ-4 which I had (another set) on my SE's. The level of grip I would say is 7.5/10 but they are very predictable and wear evenly which are important factors to me. They are 225/50/R16's on all corners.
I paid $280 with 2,500 or so miles on the tires.
I'll have to get it weighed but I figure my car around 3,000lbs in street trim and the tires have some decent meat on them so I should be ok. I will check them as I spend alot of time under my car (even when it's running fine) anyway.
The "logo" on the grill is similar to the Independent "cross" logo. It came from a breather filter I sacrificed. It was kind of a joke when I put it on and was planning on getting a Nissan emblem the next day but it actually looks good. I don't think I'll ever really be happy with my grill until I find an S5 grill I can paint black, but how heavy are those....
Morpheus- The front axle prevents the centercaps from coming anywhere close to fitting. I will probably paint my rear dustcaps black. There will be some shots, good bit of pollen around now and I want to get it aligned before I drive out for a shoot. The fronts push out to the corners just right, the rears are still going to be tucked a little.
Old Mar 28, 2007 | 03:38 PM
Fr33way™'s Avatar
Wild for Width
Those 97-99 SE's fit the 3rd gen really well IMO. (looks wise)
Old Mar 28, 2007 | 03:47 PM
Very nice.
I like.
Hum. At first I thought running without centercaps was cool/badass, since you could see the axle end and pin, but then I looked at the axle. Not attractive unless you fancy keeping it clean (no thanks). Still, it looks great. Now get some lightweight tires to go with 'em. (Toyos are usually pretty light though)
Old Mar 28, 2007 | 04:11 PM
Fr33way™'s Avatar
Wild for Width
I am a bit more form over function so they look fine to me, and yes my axles are nice and clean. Those cetercaps have to be 2.5 ounces a piece too....
|Bijan|'s Avatar
UCF Lexus
Hmm....how soon?
Old Mar 28, 2007 | 04:48 PM
RA030726's Avatar
Oh so open ended lug nuts would work to set them flush then.
225's on a 8" wide.... you must plan on going wider at some point. I used to think my 235/40's were wide, ha nope!
So how much clearance is there between the struts and tire/lip?
Old Mar 28, 2007 | 05:26 PM
Sounds like it. That will potentially be teh secks. Not sure how much I'd trust my wheels not being snug against the rotor though.
I think 245 or 255 is pretty much as wide as you want to go on a 4th gen, in front at least. And staggered on a FWD car is
Old Mar 28, 2007 | 05:45 PM
Fr33way™'s Avatar
Wild for Width
I would think that they would, yes.
Thing is, on THESE wheels going wider than 225 would require spacers all around. It's really odd I found these in this size.
I could measure the distance but I would guess around 12-14mm.
Old Mar 28, 2007 | 07:53 PM
gtr_rider's Avatar
192.168.1.1
those wheels look great on maximas for strange reason
Old Mar 28, 2007 | 09:28 PM
Way out West
Thanks.
I had a couple of sets of aftermarket wheels I liked better (I prefer black/dark gunmetal on my red car), but these wheels were super, super cheap, so I can't complain. It's hard to justify spending almost as much as my car is worth on wheels.
I like the RX wheels you have, I think they might work very well on a 3rd gen, but I am not sure about the offset in the rear. I am going to look out for a set of them locally.
Old Mar 28, 2007 | 09:37 PM
Yes... yes, it really is. Used OEM wheels FTW.
Old Mar 29, 2007 | 09:53 AM
nearthisbridge's Avatar
Nice! They really do look great on the 4th gen.
Old Mar 29, 2007 | 11:14 AM
maxima985spd
I'll buy your grille, i have a chrome one you can have.
Old Mar 29, 2007 | 08:27 PM
Fr33way™'s Avatar
Wild for Width
Thanks, but no thanks.
Old Mar 29, 2007 | 08:54 PM
Ludacris's Avatar
Looks nice man you got a helluva deal on those.
I bought my old set off a guy with a 3rd gen, they gave a great stance on the 3rd gen. IIRC the wheels were about flush with the body...I think he put 5mm spacers on the rear to fit them.
Old Mar 29, 2007 | 10:07 PM
Fr33way™'s Avatar
Wild for Width
Thanks, always liked your ride.
Old Mar 30, 2007 | 02:05 AM
lightweight 16s ftw!
not exactly how many in the maxima kingdom roll... IMO it looks badass though
Old Mar 30, 2007 | 08:36 PM
Way out West
Cool, thanks for the info. I have some 5mm spacers in the garage from the last set of +42mm offset ADRs I got for $200. haha
Old Apr 2, 2007 | 07:32 AM
TurTLe*'s Avatar
man i'm go crusie the rotary forums now. =P
freeway, what 93 is your off of?
Old Apr 2, 2007 | 05:19 PM
Jason R's Avatar
aka UNCDooD
i love the way those wheels look on a 4th gen. I wish I could find a set myself.
Old Apr 4, 2007 | 03:50 PM
Jason R's Avatar
aka UNCDooD
I might have a set of these here soon myself. I just found some locally for $250 with tires.
Old May 10, 2007 | 01:01 PM
toddemullins's Avatar
So is the offset the same front and rear? Are the rims the same? they look different front and rear for some reason. Probably just an illusion. I'm considering these for the front at least on track days.
Old May 10, 2007 | 01:03 PM
4th gen's track in the rear is smaller than it is in front. As a result, wheels with the same offset are more flush put up front then in back.
It's not an illusion, it's the car.
Old May 12, 2007 | 12:49 PM
Poowill's Avatar
damn i didn't realize how light these were! They look really good! Very good looking max as usual Fr33way... Shopping around for Te37's?
James92SE
142
Jan 2, 2024 09:23 AM
MAXSE5SPD
Sep 17, 2022 04:00 AM
ef9
Sep 29, 2015 11:29 PM
worldwiderecognized
Sep 24, 2015 06:56 PM
Pixel
Sep 15, 2015 05:53 AM
