2004 Nissan sentra ser spec-v - vq30det NO 56K!
Old May 18, 2011 | 11:42 PM
turbospec's Avatar
You may all know this car, scottys. Anyways, I bought it after he trashed and crashed it.
Core support (200 for front clip)
Fenders ($45.00 each new)
Bumper (? pull apart or a part out)
hood (had a spare, in black too!)
MAF (n62 I'm pretty sure) (got for $80.00)
Some intercooler piping (Probably some custom, one piece of it is still good ~$200)
It also needs a new transmission (3rd gear grind)
I found out AFTER he sold the car to me that it needs a ring... So thats todo too.
Ill also need an ECU, as he took it or something... (he said the shippers stole it, whatever) Ive narrowed it down that I need a 96 ecu, I assume manual. Ill be getting a JWT reflash that Travis had custom tweaked for the car.
Pics 2/23:
Bump.
Begining of may:
First off: Took off turbo, wastegate, some piping, radiator, hoses,, unclipped alot of the harness that lines the front of the car, pulled all wires away from driver side fender curtain, pretty much prepped for the work. Finally, cut the harness in two (sad day, working on resoldering it now)
Heres the car prepped.
Donor clip:
Donor clip with what we needed taken off:
Car prepped:
Welded on:
filled in:
Finished product with a passenger fender and an old driver fender and hood I had installed for line up purposes:
Also, found this, this is the portion that comes off of the headers, as you can see, inside the flex pipe sits a bunch of flex pipe jumbled up, likely restricting exhaust flow to the turbo. I may have to replace this...
Old May 19, 2011 | 12:46 AM
6.5affiliate's Avatar
Wow, looks like you got a LOT of work ahead of you. Interested in seeing how this ride is going to progress
Old May 19, 2011 | 06:53 AM
speeddemon1214's Avatar
Subscribed_
Old May 19, 2011 | 06:58 AM
DrunkieTheBear's Avatar
Turbo'd Saab
So sad to see some trash a ride like this after all that work. Looks like your putting right back on the right track. Kudos to you my friend, I love builds like these.
Old May 19, 2011 | 07:52 AM
nismoSEXIMA's Avatar
do i spy a MEVI on that thing? if so have you considered a 00vi swap?
Old May 19, 2011 | 11:10 PM
turbospec's Avatar
yep with an rpm switch (if you can see, it shattered the housing, but somehow the circuit board was intact surprisingly)
I may do an 00vi wayy down the road. Right now my goal is: Ecu, Ic piping, get it running pretty much for now.
Bought a hks ssqv vIII today limited black edition (110shipped!)
As of now my plan of attack is:
Stock ecu (before reflash)
ic piping
Then do compression test.
When I figure out how bad the ring is/which one it is, and ill go from there.
If I end up pulling the engine ill probably go with rings/bearings and a trans while its out.
Old May 20, 2011 | 06:30 PM
Nice I'm def subscribed to this thread I'm anxious to see how it looks and runs when your done! Good job so far!
mvm062
Nov 30, 2020 09:00 AM
Mar 12, 2020 12:06 AM
RinconI30
Nov 10, 2015 10:55 PM
wingnut2006
Sep 19, 2015 06:13 AM
coasterswim
Sep 2, 2015 07:43 AM
