My 98 Max : JIC Coilovers+fender rolling+G35C rims...now boosted
Old Oct 6, 2011 | 08:36 AM
  #41
JustALTF4's Avatar
What kind of grill is that? Stock with a mesh grill painted black?
Old Oct 6, 2011 | 09:43 AM
  #42
Snypa's Avatar
5mm wont do anything.
I tried 15mm & 20mm.
Old Oct 11, 2011 | 06:17 PM
  #43
Originally Posted by QT1 5MT AE
5mm would do in the rear. 10 might rub with passengers.
when are you picking up my sterling mist stillen sides and rears?
Whatchu talking about? Didn't know you had anything. Figured it all went with the sale of your car. If mint, let's talk.
Agreed. 5mm is near worthless, IMO.
I'm thinking I need 10mm or 15mm, but gotta do some exact measurements to be sure.
5mm=0.2"
10mm=0.4"
15mm=0.6"
20mm=0.8"
25mm=1"
Old Oct 11, 2011 | 10:17 PM
  #44
QT1 5MT AE's Avatar
Gram Lights addict
5mm=0.2"
10mm=0.4"
15mm=0.6"
20mm=0.8"
25mm=1"
these are the only mods i got left. kit is in good condition but not mint. i'd say its in good shape for a DD.
http://forums.maxima.org/4th-generat...s-97-99-a.html
http://forums.maxima.org/4th-generat...reddy-sp2.html
5mm is on the safe side. 10mm might rub with driver in rear. 15 you're nutz. thought this is a DD
Old Oct 11, 2011 | 10:30 PM
  #45
QT1 5MT AE's Avatar
Gram Lights addict
I just did some calculation based on my old setup. IIRC these g35's are 18x8 +30 right? with a 15mm spacer your rear rim would sit a mere 5mm closer to the shock than this picture.
considering those squared out sidewalls, you will shred the heck out of them. I will stick with 5mm if you want to have passengers in the rear. even 10mm is pushing it. the setup you see above is a 10" +35 on 235/40...... I know your math is solid so punch in those numbers
Old Oct 12, 2011 | 04:57 AM
  #46
Shift_Max's Avatar
At least 10mm is probably needed.
Old Oct 12, 2011 | 08:28 PM
  #47
Snypa's Avatar
I dunno guys, but i aint rubbing and i carry people in the back. I'd go with 15mm. I have them and I can vouch by it.
Old Oct 26, 2011 | 05:56 AM
  #48
Puppetmaster's Avatar
Very nice work with the car. 9 kgs in the rear? Is that their factory spring rate or did you special order that? It's rare to find a set of coils with higher rates in the rear.
Old Oct 26, 2011 | 09:09 AM
  #49
I was just thinking the same. 9kgs is very high for the rear. If 8kgs are up front, the rear should be 7kgs or less.
Old Nov 1, 2011 | 05:35 PM
  #50
wirelessdude04's Avatar
update?
Old Nov 1, 2011 | 06:25 PM
  #51
max_dreamer's Avatar
not sure if it helps, but you know ive got the g35 19x8.5's all the way around. rear tires are 235/35/19 conti extreme contact dws with 8mm spacers... just another look. im a little closer in width than QT1. plus i had to chime in with some more Sterling goodness!
oh, and considering im tucken a little tire and have only managed to rub off the lettering on both sides, you could prolly go with 15 and not scrape... what setting you on? im rockin 7 front and back to keep me from rubbing.
Old Nov 3, 2011 | 07:18 PM
  #52
Puppet and Chris,
I pulled that info from the website. I thought it was odd too. I did not special order. See link:
http://www.jic-magic.com/ViewProduct...48&CarMakeID=7
Originally Posted by wirelessdude04
update?
Probably gonna drop it more tonight since I have to do a rear brake job.
Thanks for the pic, that does help. I have my front and back coilovers set at full stiff.
Been swamped with work and other crap. Gotta find some time to make some real progress/get spacers etc.
Sterling Mist crew in da house! LOL
Old Dec 30, 2011 | 09:30 AM
  #53
Shift_Max's Avatar
Any updates on this?
Old Dec 31, 2011 | 02:50 AM
  #54
Grand_hustle17's Avatar
for coilovers..... so sexy
Old Jan 2, 2012 | 12:35 PM
  #55
Leo_Koneval's Avatar
Looks beautiful! Very magical, enchanting, spell-binding!
Old Jan 5, 2012 | 11:11 AM
  #56
95maxrider's Avatar
Lightly modded
I'm curious about the spring rates you have for the coilovers. Is 8k front 9k rear correct? How does it ride compared to your other car? Do you think having 9k in the rear is too stiff or unstable for daily driving?
Old Jan 7, 2012 | 01:48 PM
  #57
Unfortunately, no updates. Between life and work, things have been busier than ever lately.
Thanks Leo. Nice choice of words. LOL
I've been meaning to call JIC to verify, but I haven't.
The JIC's are more firm/stiff than the Progress coilovers, that's for sure. I do have them on full stiff though. I plan on putting them on full soft very soon so I can see the difference in ride quality and how they compare to the Progress coilovers. Ultimately, I think I'm going to switch the coilovers from my Maximas. The Progress coilovers are definitely more like "daily driver" coilovers in my opinion.
Old Jan 8, 2012 | 01:27 AM
  #58
kk8909's Avatar
nice coilover u got there
Old Jan 13, 2012 | 08:38 PM
  #59
Shift_Max's Avatar
Question for you in regards to the front fenders and the fender liners. You rolled the front fenders all the way to the point where the lip is folded in and then you cut the liners in the location where they were secured to the fender? How are they being held there now?
Old Jan 14, 2012 | 08:40 AM
  #60
Crusher103's Avatar
The force.
Old Jan 14, 2012 | 10:11 AM
  #61
The fender liners will float in place. All the inside mounting hardware is enough to keep it pretty stable. Plus you can kinda tuck it behind the folded lip. Or at least that's what I did. BUT!!! At one point I hit a huge pothole and my tire went far enough up into the fender to dislodge the liner and then just tore holes in it... I ended up having to pull over and cut it out.
Just my $.02
Old Jan 14, 2012 | 10:19 AM
  #62
I demand updates.
Old Jan 16, 2012 | 11:06 AM
  #63
dna59's Avatar
Nice suspension setup you have there as well as choice of rims.
Old Jan 16, 2012 | 11:35 AM
  #64
QT1 5MT AE's Avatar
Gram Lights addict
yes... updates?
Old Jan 16, 2012 | 05:03 PM
  #65
95maxrider's Avatar
Lightly modded
I'm curious to hear if those spring rates are actually correct and how the ride quality improved when lowering the damping setting.
Old Jan 31, 2013 | 11:07 AM
  #66
4thKizyle99's Avatar
Did you just "bend" the lip in or did you roll the fender out some?
Old Jan 31, 2013 | 11:12 AM
  #67
Well, I bent the lip in flat using the fender roller. That was my primary goal. So much force was necessary to roll the fenders that I wouldn't be surprised if I rolled the fenders out 2 or 3 mm's w/o even trying.
Old Jan 31, 2013 | 12:16 PM
  #68
renots's Avatar
I need to get my fenders rolled.
Oh an this the first time I've seen any of your other maximas haha only seen the 99 an pics of the i30 an supra.
Old Jan 31, 2013 | 12:29 PM
  #69
aackshun's Avatar
Is this car and any of my maximas ever going to be in the same place ever again?
Old Jan 31, 2013 | 07:36 PM
  #70
Shift_Max's Avatar
Probably not
Old Feb 1, 2013 | 02:43 PM
  #71
aackshun's Avatar
Old Feb 5, 2013 | 12:23 PM
  #72
Flava_24/7's Avatar
Boosted Panda
Is your red Maxima ever going to be running again?......
Old Feb 5, 2013 | 02:37 PM
  #73
aackshun's Avatar
Good question, I'm at a point now where I'm ready to sell my current project off and build my dream.
(Just depends on how successful the white car is @ IFO)
Old Feb 5, 2013 | 04:09 PM
  #74
Flava_24/7's Avatar
Boosted Panda
What? Really?
After all those posts about the different builds and claims your not even gonna get it running?
Old Feb 5, 2013 | 11:25 PM
  #75
Rods03Max619's Avatar
When you see all of them your Mouth is going to Drop Like DAMMMNNN.....
Old Feb 20, 2013 | 12:47 AM
  #76
Gonna have some updates here pretty soon...
Old May 12, 2013 | 07:15 PM
  #77
Teaser pic
Old May 12, 2013 | 09:20 PM
  #78
DrunkieTheBear's Avatar
Turbo'd Saab
So this is where all the supercharger kits went LOL
Old May 12, 2013 | 09:25 PM
  #79
Waiting on that PM...
Old May 12, 2013 | 10:43 PM
  #80
mista0406's Avatar
If you haven't already you should get some 2005 murano center caps... they fit perfect as you can see in my sig Wiz... also I have 15mm in the rear and 5mm in the front on 235/40 all around
