i think i just short circuited something... help!
Old Jul 11, 2002 | 09:19 PM
JPLW26's Avatar
i was rewiring the corner lights and i put in the 10 W fuse instead of 7.5 cause 7.5 blew and 10 W blew after 2 tries... and so stupid me even though i knew i shouldnt have... i put in the 15W and it didnt blow but im pretty sure i short circuited it... cause my gauges dont even come on when i turn it on... so how much is this gonna cost me? and yea is there a easy way how you guys brightened ur corner lights?? did ur fuse not blow when u rewired it?... any other suggestions on how to do it? thanks guys
Old Jul 11, 2002 | 09:27 PM
mb1's Avatar
mb1
first look for any other blown fuses. Next time just sand down the ***** on the bulb and put it in backwards.
Old Jul 11, 2002 | 09:30 PM
itsgt's Avatar
Re: i think i just short circuited something... help!
you must've rewired them wrong that's why its short circuting. Either over look your setup and see where the problem is or just put all the wiring back to stock as it was. Then go through all your fuses and make sure they're good.....the 2 fuses that usually blow are the 7.5a "TAIL L." fuse which is under your steering colum fuse box...and the other is the 15a fuse which sits in the fuse block near the battery.
good luck.
Old Jul 11, 2002 | 09:53 PM
JPLW26's Avatar
Re: Re: i think i just short circuited something... help!
good luck.
well i have blown a fuse doin it before and when i did blow it at least my gauge lights came on but when it tried the 15W in the tail light fuse nothing came on and even my gauges light wouldnt come on... but the fuse didnt blow (15W) so i dont know whats goin on... but yea what are u guys talking about putting the bulb in backwards??? how would u do that
Old Jul 12, 2002 | 06:35 AM
1MAX2NV's Avatar
You probably fried the dimmer switch or burned up the wires. This is going to cost you $$$ to fix. Aleast $250 for someone to troubleshoot it and fix it for you.
jmlee44
Oct 2, 2022 02:13 PM
gavin68
Sep 18, 2021 12:36 PM
gigabyte
Jan 6, 2017 06:05 PM
sliptap
Sep 30, 2015 05:57 AM
