99 Max SE oil level
Old Jul 14, 2002 | 02:04 PM
rich1223's Avatar
99 Max SE oil level
After returning to the dealer to inspect the car one last time before deciding whether to buy i pulled the dipstick to check the oil it was in fair shape not to dirty or clean but the problem is the level after i wiped the stick clean and pulled it back out the oil ran pretty far passed the full mark can you say overfill i repeated this a few times no change their is definately to much oil and i know this is bad for the car.Now my question is could the dealer or previous owner be trying to hide something by adding to much oil?when the car is running it sounds fine but don't think you should be running the engine to often with to much oil.Any opinions this is really making me have second thoughts thanx.
Old Jul 14, 2002 | 04:25 PM
xHypex's Avatar
I don't know how you checked the oil, but our dipstick is probably the worst thing ever designed It took me forever to get accurate oil readings because of the poor design.
Now I warm up the car slightly, then let it sit 10 mins or so so the oil can drop back into the pan. Put the dipstick in "upside down" with the dipstick pointing down towards the front of the car. Then pull the dipstick out and flip it over "right side up" to view the actual oil level.
Hope that helps.
-hype
Old Jul 14, 2002 | 05:27 PM
kmax's Avatar
If the car is cold then yes the oil level is going to appear to be too high. Like xhypex said warm it up, shut it off and check it after 10 minutes.
Old Jul 14, 2002 | 05:44 PM
rich1223's Avatar
thanks i will give it a try when i go back to the dealer
captchaos
Mar 15, 2016 12:18 PM
kjlouis
Oct 3, 2015 05:29 AM
Vequity
Sep 10, 2015 05:26 AM
ag90fox
Sep 9, 2015 12:22 PM
dcardello
Sep 3, 2015 11:44 PM
